Page 2 of 4
Re: Over fueling or Injectors or Something else
Posted: Wed Oct 28, 2015 10:56 am
by Enzio
Those are stock injectors.....harness connectors are normal Bosch EV1 type and can be bought at most parts shops
Posted: Wed Oct 28, 2015 11:59 am
by Jaco1981
Enzio wrote:Those are stock injectors.....harness connectors are normal Bosch EV1 type and can be bought at most parts shops
Awesome, thank you very much!!!
PS, what is this item for?
Posted: Wed Oct 28, 2015 1:17 pm
Dumpvalve for realising the pressure in the boost pipes so so the turbo doesn't surge and get damaged
Posted: Wed Oct 28, 2015 1:35 pm
by Enzio
It makes a stupid noise and makes your car run poorly
Common ricer mod on these cars, it might even be part of the reason for your idling issues.
I had one on my car that leaked under vacuum (idling)
by Jaco1981
SonOfAnarchy ZA wrote:Dumpvalve for realising the pressure in the boost pipes so so the turbo doesn't surge and get damaged
The thing is this. That blue line is not connected to anything, its just hanging there.
The pic below, is from another angle, just before the intake, is a dump valve that is hooked up?
So is it safe to say, that might be an old dump valve that is not working anymore?
PS, is it normal for this setup to have the waste gate on the turbo itself welded shut?
Posted: Wed Oct 28, 2015 1:39 pm
by Enzio
Wastegate welded shut?
Does it have an external wastegate? (I cannot see one in the photos)
Since the previous owner left a redundant dump valve there I am starting to see what kind of car you bought.....hope you get it sorted and do a better job than the previous owner.
Posted: Wed Oct 28, 2015 1:40 pm
No its not, do you have a pic of that?
Posted: Wed Oct 28, 2015 2:32 pm
by Jaco1981
I was aiming for a stock one, but gave up after a few months. This one is not to far gone, well, it looked that way when I bought it.
Charlvdw wrote:No its not, do you have a pic of that?
Think that might have been a false alarm. Will confirm it when the injectors are back in
Posted: Wed Oct 28, 2015 2:35 pm
Only reason one would weld the wastegate closed is if u using a external wastegate but that's not the best move send more pics
Posted: Mon Nov 09, 2015 2:55 pm
by Jaco1981
Ok, so I took the injectors to SAC, they advertise on their website, that they can refurbish injectors. They then told me that they need to send it to JHB. So eventually we spoke on Friday, they said they cant repair it, its to far gone. I'm a bit confused, but ok.
Do you guys know any other places around Cape town that can have a look at injectors?
I saw on Facebook a guy somewhere upcountry, breaking a SX. Contacted him. Sold me the injectors, fuel rail and regulator. Made payment today and waiting for it to arrive. Hope they are in better shape!!
Posted: Mon Nov 09, 2015 4:11 pm
by Enzio
Go to your nearest Bosch service centre. They do the ultrasonic cleaning, flow testing and repairs.
Posted: Tue Nov 10, 2015 9:44 am
by Jaco1981
Enzio wrote:Go to your nearest Bosch service centre. They do the ultrasonic cleaning, flow testing and repairs.
Thank you very much, will do that once my set have been returned.
Posted: Tue Nov 24, 2015 4:42 pm
by Jaco1981
Ok, so the injectors came, turn out to be the wrong injectors, and dont even fit the rail
So, moving on. Does anyone here have a set of stock injectors they want to sell?
Posted: Tue Nov 24, 2015 9:41 pm
I have a set they need new o rings
Posted: Wed Nov 25, 2015 1:06 pm
by Jaco1981
This is so strange. The guy I took my injectors to, phoned me now and told me, he had the injectors at 6 bar and it did not drip, according to him, they are not in bad shape and only need a good cleaning. He also replaced the caps (those caps on the manifold side. Will have them back by Friday.
So now, the question is this, how does the petrol get into the oil? If its not the injectors dripping and the motor is not overfueling......
