Project s13 RB25 Neo Capetown
- White Fang
- Real Name: Qubitt (Qbit)
Re: Project s13 RB25 capetown
ja ask TOBI
HIS GOT 25 OF THE KITS ,
well worth the buks !
and keeps the motoe 100% for many miles !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PS : dont tnune TOBI kak HE IS MOERSE , HY SAL JOU ! PK GEE DAN SAL JOU MA DIT VOEL
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
- k.y.l.e.
- Real Name: kyle
Got a few items for my motor to ensure proper built base.
Cometic head gasket
RB25 freddy intake brand NEW thanks to ACT performance
Cometic head gasket
- k.y.l.e.
- Real Name: kyle
and how exactly are you going to attach the top radiator hose to that manifold.........?
- RB25SX
Dont replace stock gasket, unless u want to open the motor. Stock gasket can handle a good amount of boost before it will blow.
R32 GTR
- k.y.l.e.
- Real Name: kyle
Thanks bk
going to buy a piece of billet alumiuim about 45cm in diameter and 30mm thick and put it on the lathe and make somthing almost the same, tell me bk can i route the drain pipe into the oil return with a t-piece? or is it beter on its own?My LuGnuts have more torque than your honda.
Better on its own bud. I changed this setup due to the turbo drain going all the way to the front drain hole you see ahead of the mounting. My head drain now goes there and the current pic setup is now used for the turbo drain.
As per the Nocsa posts, I dont know if its drain back or more breathing that helps cure the oil spew problem here, all I know is it worked for me.
I had 4 liters spew out the breathers once with my old RB motor..not good.
- k.y.l.e.
- Real Name: kyle
lil update, gearbox fitted to motor need to into car to make the engine mounts.
Motor in
so now time to make mountings.
Motor sitting waaay to close to rad, due to me using a sr2odet gearbox with rb25 bell housing
Didint know rb25det is more motor than dam car lol.
Motor in
- k.y.l.e.
- Real Name: kyle
- RB25SX
Dont fit it like that, its easy enough to make gearbox mountings to move gearbox back
R32 GTR
- k.y.l.e.
- Real Name: kyle
Gearbox mountings made and motor moved back
- k.y.l.e.
- Real Name: kyle
Small update!!!
Steel for the mounting got some 12mm thick mild steel, got the tricky pieces lazer cut for awsome finish.
Rough finishing product mountings need to be neatened up and sending away for epoxy coating.
Gearbox mountings done and moved it one hole back in order to bring the motor back a lil.
- 0.9 Bar Boost
- Real Name: ????
nice stuff man..
