injector sizes?
300sx
0.8 Bar Boost
Re: injector sizes?
Post by 300sx »
how is ca18det stock ecu different from a sr20 stock ecu?? very little difference between management..
ca18's only curse was a small turbo.. not that it mattered for what it was built for, i well remember when my s13 was new, it ran off the clock with ease..
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
robldepo
Real Name: robert
Re: injector sizes?
Post by robldepo »
Yes please how mutch do you want for it? The regulator that is.
Re: injector sizes?
ag guess you can just have it dude
robldepo
Real Name: robert
Re: injector sizes?
Post by robldepo »
thanks a lot man really aprreciate it i stil, have to pop around to your place looks like the car is semi sorted out now but over fueling at the moment and that's with the OE fuel pump somehow somewhere they managed to increase the fuel pressure but i have no idee how, there is no tel tale sighns that i can see.
Re: injector sizes?
it could be the regulator not opening. come around we will sort the over fueling out one shot
Re: injector sizes?
Sorry Sonofanarchy, gonna screw up ur sale, my advice is to get a proper after market one where you can also see the fuel pressure.
Re: injector sizes?
not gonna screw it up considering im giving it to him but i agree with you but on a tight budget which most of us are on free stuff is better than stuff that makes u open your wallet :mrgreen: [smilie=200sx_200sx.gif]
Re: injector sizes?
True....been there done that....do so still unfortunately...
Grobblere
0.6 Bar Boost
Real Name: Eugene
Re: injector sizes?
Post by Grobblere »
I have had both the stock Sr20de managements and the ca18det managements, the ca18det managements are ALLOT more prone to giving errors with the water sensors and the knock sensors causing them to go into limp mode. The Sr20de managment could cope with heavy mods like cams ans, whereby it would adjust to the new hardware (If you installed cams then the car might die once, but then never again) The only problem with the sr's where the air flow meters which tended to die after 200 000 km's+.
When the ca motors gets flooded they are extremely hard to restart. They are also sensative to high fuel pressures with the stock management and hard to start should there be an issue in this regard (Even with a new pump on stock regulators)
