Lazy eye
- POWDER
- Real Name: Mike
Re: Lazy eye
I see Daz has already jumped in, was gonna say come copy my wiring.. . Lol
I still need to individual controll settup though, lol
Re: Lazy eye
after a bit of thought there is a easy way around it wire in a on off switch that will disconnect the brown wire, this way the motor moves down with power and u just disconnect the brown wire at the correct height you want it.
robldepo
- 0.2 Bar Boost
- Real Name: robert
Re: Lazy eye
sweet guys ill keep you posted on what im going to do
- POWDER
- Real Name: Mike
Re: Lazy eye
The brown wire only gives permanent power to the ret control, so ye if you want selectable with bron wire permanent normal ret and then adjustable, yes a switch will work, but you will still need to tap the button to select your hight. And the brown wire must be inactive before you start the car and must be adjusted before the car is started.
robldepo
- 0.2 Bar Boost
- Real Name: robert
Re: Lazy eye
Ok so we've had a look of some pics on ebay of the lazy eye controller kit and we have come to the conclution that all it is is a unit that u just tap in to the brown wire and it gives u the POD witch allows you to basicaly set your lazy eye to the hight that you want them and the only way it can do that is by power the brown wire for a short period of time so it works on the same principle as the switch that some guys put in, so we are going to build a unit that by the touch of a button wil only give the wire power for a second or so and this should do the trick.ill keep you posted
Re: Lazy eye
you basically need a timing circuit with a relay use a lm555 should work
robldepo
- 0.2 Bar Boost
- Real Name: robert
Re: Lazy eye
jip the lm555 is what im using in my "injector tester" so it should work for the lazy eyes
Re: Lazy eye
hey guys soooo i cut the brown wire . lights dont move now .....that button that makes the lights pop up doesnt work any more. only when i turn my lights on do they lift up .. help
NIZAN-R
- Real Name: Renier
Re: Lazy eye
push lights lift (it wont open)
turn on lights (it opens)
turn of lights (lights stay open)
push light lift like a mouse click double click to drop and stop (trail and error to get perfect)
Re: Lazy eye
ja try watching this vid might help http://www.youtube.com/watch?feature=yo ... HLgIibASP8
Re: Lazy eye
thanks hahahaha will give it a try
Re: Lazy eye
if you dont come right let me know
robldepo
- 0.2 Bar Boost
- Real Name: robert
Re: Lazy eye
just a few more days then my boss will be back from the states with my lazy eye controller kit then i can open it and just copy it maybe make a few and sell it to the guys on the forum that realy (like me) dont whant to cut the brown wire, just need to test it first
- POWDER
- Real Name: Mike
Re: Lazy eye
OK, so I have been watching this thread and still noone has figured out the lazy eye settup.... Would people like to see if I have the skillz to work out a fully adjustable lazy eye settup? With selectable lazy eyes? Hight adjustment and selectable left right or both ?
I'm sure I can figure it out and am more than happy to take up the challenge.... Obviously no cheating by using an existing lazy eye kit or anything....
Or how about this, we see who figures it out first?
Re: Lazy eye
Is that a challenge?
