i thought they were made of some sort of plastic, because my engineer calls them plastiguage or something like that!!!
but yeah, they put everything together with those strips in place, then disassemble it and measure the thickness of the gauge! thats what i've heard.
- Vlade
- * - Club Pimp - *
- Real Name: Barend
Yip it can
but not sure its the case here, we havn't touched the flywheel/clutch stuff.
Also one can normally feel it when its unbalanced, there is a vibration right through the RPM range, I didn't align my flywheel with the alignment pin on my first engine, took it to a clutch place so they can sort the vibration and replace the worn clutch...
I asked the dude what caused the vibration he told me some idiot didn't align the flywheel to the alignment pin...
School Fees
so you guys didnt send the engine in for balancing then???Vlade wrote:Yip it canbut not sure its the case here, we havn't touched the flywheel/clutch stuff.
I asked the dude what caused the vibration he told me some idiot didn't align the flywheel to the alignment pin...![]()
School Fees
i spoke to toby about this, and its not expensive. maybe if you have everything out again, send it in before its reassembled!!!
i think my balancing and weight matching (blueprinting i think its called) cost in the region of 500 bucks!
they asked me for pistons, rods, crank, flywheel, clutch assembly, crank pulley, etc. and it was a day turnaround!!!
i think if its possible now, you guys should do it!
The Calibrator
The big end thats shiny on the one side is from the journal being taperd.
lemme guess it wasnt Allan Y Brink?
those guys mike every bearing and every journal no no platigauge or guesswork.
Plastigauge is the name of the product and its only a guide of whats happening.
I normally only use it to double check that the bearings are the right size for the journal.
