still busy with the cluster....
but here are a few more shots of my new turbo....
but I encountered a few probs....
the manifold doesn't want to fit flush with the turbo.... otherwise it looks AWESOME!
what you mean it doesnt fit flush???
veecee wrote:what you mean it doesnt fit flush???
here's a pic...
I bolted it down and it gave the same effect...
This is where the manifold catches on the turbo...
HancoB
Post by HancoB »
Oh ja forgot to tell you riekert...
You have to clock the turbo about 2 or 3 degrees and change the stud to a shorter one.
HancoB wrote:Oh ja forgot to tell you riekert...
ah... I knew that.... :oops: :oops:
When I put my T28 I just grinded a mm away.....
HancoB
Post by HancoB »
Or you can do that...
mmm.... grind the manifold?? that might work... the mani is quite thick isn't it. I think I should do that... cause otherwise the piping is gonna be a bit weird. thanx I think I'll do a bit of surgery on the manifold... :twisted: :twisted: :twisted:
HancoB
Post by HancoB »
The piping will be weird anyway.
You will see! :lol: :lol:
HancoB wrote:The piping will be weird anyway.
true, but if i "clock" the turbo the piping will be showing down and not to the side... but ja... will check what I can do! :twisted: :twisted:
HancoB
Post by HancoB »
No not really, remember how mine was?
Yours will be exactly the same.
HancoB
Post by HancoB »
Oh ja, and don't forget to put a gasket in between the manifold and turbo, or use some gun gum atleast if you cant find a mani.
That will also give you a bit more clearance and the studs will fit.
And all the custom piping does fit just with a bit of a stretch.
Ah... ok.
Oh and the gasket I still got. so it should suffice.
thanx
HancoB
Post by HancoB »
Coolio! :wink:
Now I just need to mod the actuator...
The one I have in the new turbo is bent to fit... the one off the t25 is straight... hammer anyone! :twisted: :twisted:
