Project F
- ChemCool
@Gary=silicone pipies from boys for toys in sunnyside Pta. Try Autostyle Gary. You get them yellow,blue and red.Different diameters etc.
Thanks so far. Ero you welcome. pop in some time.I think the engine must
come in this weekend. Still need turbo flench, some belt to pull engine on block and tackle.Cleaning material.,
Chem
- ChemCool
Today, my s13 decided to quit. Not the bearing knock, just dropped in revs down to 400 and would not idle then. Drove home with full throttle to keep the engine going. Changed sparkplugs and all 4 x coils. Nothing.
Changed the CAS, nada. Boost leak??? Cant seem to find it if any?
Injectors all 4 x injector relays active when CAS shaft is turned.
Feul is pumping nicely to the stock fpr. Engine like running on 3 cylinders.
Boost looks good on boost meter. Terrible leak between local made downpipe and turbo exhaust housing. Plan was to rectify that with motor swop. Draco and me feel that the latter cant be the problem. no smoke out of exhaust. Dont know about AFM? I just dont really need this before the engine swop!!!!
Which must be this coming weekend.
- Toby
- Club Founder
- Real Name: Toby Kurien
Coil maybe? Like you said, running on 3 cylinders, so maybe coil, spark plug, or loose electrical connection. Unplug each coil one-by=one to see which cylinder it is, then swap it's coil with another to see if problem moves with coil.
BTW, I'd like to come have a look-in when you do the engine swop on Saturday... let me know when
- ChemCool
http://200sx.za.net/phpBB2/viewtopic.ph ... &start=120
No, to much schools on this one. One of those topics again. The one say so and the other that. Stuff them all.
Chem
Chem
I cant see that it would make that much difference, it probably does make a negligible tiny bit.ChemCool wrote:http://200sx.za.net/phpBB2/viewtopic.ph ... &start=120
Chem
Defused will flow more if the waste-gate is made a screamer pipe.
But bell mouth on average will allow more flow over a integrated defused unit.
Look we are arguing over a small difference here,
