Page 9 of 20
Re: Devil Pig Drift / Track car S14 Ls1v8
Posted: Tue Dec 18, 2012 9:20 pm
by Booster
Pics and video to follow :wink: :mrgreen:
Posted: Tue Dec 18, 2012 10:02 pm
by Booster
Front right oil filter, oil pressure and oil temp sensors
Under motor - the matrix
Dry sump pump mounted
Posted: Tue Dec 18, 2012 10:08 pm
by Booster
Branches - really tight but I'll use heat wrap and shielding to look after starter etc
Dry sump pulley drive off of damper pulley
Wiring on gauges sorted
Posted: Tue Dec 18, 2012 10:13 pm
by Booster
More plumbing
Power steering fittings
Here you can see the 60-2 machined on inside of damper pulley. Needed to play around with crank angle sensor - Hense test wires hanging
Break lines in
Radiator clearance
Posted: Tue Dec 18, 2012 10:16 pm
by Booster
Rear lines
Posted: Tue Dec 18, 2012 10:23 pm
by Booster
Posted: Tue Dec 18, 2012 10:26 pm
by Booster
First start up :shock:
Running motor to temp
Checking oil pressure, oil leaks, water temp and or leaks
All good no leaks pressures all good
http://i1105.photobucket.com/albums/h35 ... 39A6B0.mp4
Posted: Tue Dec 18, 2012 11:18 pm
by Daniel
Awesome, such quality work! I I dream of those skills.
Sent from my GT-N8000 using Tapatalk 2
Posted: Wed Dec 19, 2012 6:26 am
by BigKriss
You still have the std S14 front end stuff, headlights, bonnet, bumper etc ?? If so, want to sell ??
Great build here btw.. :wink:
Posted: Wed Dec 19, 2012 6:56 am
Awesome build man!!! :o:grin::mrgreen:
Posted: Wed Dec 19, 2012 7:09 am
by Booster
BigKriss wrote:You still have the std S14 front end stuff, headlights, bonnet, bumper etc ?? If so, want to sell ??
Thanks man. Unfortunately for the time being I'm using the original stuff. It will be going onto the car shortly.
I removed it all during fabrication and instillation
Posted: Wed Dec 19, 2012 8:10 am
by Vince
Man O man I cant wait for this car to hit the track and SA drift scene.....
With that awesome V8 it is definitely gonna be a crowd pleaser
Posted: Wed Dec 19, 2012 8:47 am
dam thats real awesome great workmanship
Posted: Wed Dec 19, 2012 8:34 pm
by DriftZ
Booster wrote:First start up :shock:
I want a man in blue overalls!
.. glad theres been progress! big potential to be one sexy slider.
Posted: Wed Dec 19, 2012 9:28 pm
by BigKriss
Ah, ok. Saw you had S14.5 /Silvia headlamps in..
