Devil Pig Drift / Track car S14 Ls1v8
Re: Devil Pig Drift / Track car S14 Ls1v8
Pics and video to follow
Front right oil filter, oil pressure and oil temp sensors
Under motor - the matrix
Dry sump pump mounted
Branches - really tight but I'll use heat wrap and shielding to look after starter etc
Dry sump pulley drive off of damper pulley
Wiring on gauges sorted
More plumbing
Power steering fittings
Here you can see the 60-2 machined on inside of damper pulley. Needed to play around with crank angle sensor - Hense test wires hanging
Break lines in
Radiator clearance
Break lines in
Radiator clearance
Rear lines
First start up
Running motor to temp
Checking oil pressure, oil leaks, water temp and or leaks
All good no leaks pressures all good
http://i1105.photobucket.com/albums/h35 ... 39A6B0.mp4
- Daniel
- Real Name: Daniël
Awesome, such quality work! I I dream of those skills.
Sent from my GT-N8000 using Tapatalk 2
You still have the std S14 front end stuff, headlights, bonnet, bumper etc ?? If so, want to sell ??
Great build here btw..
Awesome build man!!!
:mrgreen:
Thanks man. Unfortunately for the time being I'm using the original stuff. It will be going onto the car shortly.BigKriss wrote:You still have the std S14 front end stuff, headlights, bonnet, bumper etc ?? If so, want to sell ??
I removed it all during fabrication and instillation
Man O man I cant wait for this car to hit the track and SA drift scene.....
With that awesome V8 it is definitely gonna be a crowd pleaser
dam thats real awesome great workmanship
- DriftZ
- Car: S15
I want a man in blue overalls!Booster wrote:First start up![]()
.. glad theres been progress! big potential to be one sexy slider.
Ah, ok. Saw you had S14.5 /Silvia headlamps in..Booster wrote:Thanks man. Unfortunately for the time being I'm using the original stuff. It will be going onto the car shortly.BigKriss wrote:You still have the std S14 front end stuff, headlights, bonnet, bumper etc ?? If so, want to sell ??
