Page 9 of 17
Posted: Mon Jul 12, 2010 12:08 pm
by hentiebez
well done PFB
Posted: Mon Jul 12, 2010 12:57 pm
Not bad at all.
Posted: Mon Jul 12, 2010 1:30 pm
by Enzio
Ha!, no wonder you can smack those GTIs and STs...
Posted: Mon Jul 12, 2010 2:51 pm
by Sokar
I'm just sooooo glad you didnt paint the valvecover blue...
Also, the lumina ran a 15.7ish on friday too, might have been a 15.9... That is all...
Posted: Mon Jul 12, 2010 3:00 pm
by Enzio
Eish Sokar....that's harsh
And your lumina did what?
Posted: Tue Jul 13, 2010 9:05 am
by Pinkfluffybunnys
Thanks Guys, I was impressed myself
Its in his Post.
Posted: Tue Jul 13, 2010 9:08 am
by Enzio
Yeah, I know.
BTW, I'm gonna try to arrange to come through to your neck of the woods this weekend. Will call if I do.
Posted: Tue Jul 13, 2010 10:38 am
by Pinkfluffybunnys
Yeah, I know.
Cool let me know.
Posted: Mon Jul 26, 2010 7:56 am
by Pinkfluffybunnys
The cams are in. Changed the cam timing a little
Stock Cams
N1 Cams Vs Stock
Technical
Because I couldn’t get on a dyno before the install I took the Sentra for a spin around the block on the morning logging data and the AFR’s, After the install I Did the same thing keeping the redline at 7300Rpm just for the data run.
After the install on start-up the car at idle the motor was consuming more air, I could see this on both the TP value and the MAF voltage returned, Taking the car around the block, I had to richen up and extend the TP value of the map (Basically the pulse width at 7000Rpm when compared to my old data log , I had to add 11% more fuel to keep my 13.2 AFR, I had on the old cams.
I settled on a +4\-4 Cam timing after trying 0\0 and +2\-2, When logging data on those settings the MAF and TP wouldn’t match the values received on +4\-4. I know the testing isn’t as accurate as a dyno but it defiantly showed results when logging.
I played around with he cam switch points , I eventually settled for 5100Rpm switch on both cams
Impressions
This is where things get interesting to me the car feels slower but the nistune system offer like a stop watch system based on RPM and I can see the car is quicker on the system plus, I can see the car is consuming more air but one thing, I can say is the car is allot louder especially in lift. I’m now really considering going with a 76mm exhaust system for the car.
On a Side note, I also drove my SX around yesterday and all I can say is if the SX’s got a good pull away it would cream my sentra. Driving the SX is like driving a roller coaster it breaks traction mid first gear and the only way you get it back is by stepping off the pedal and will easily break with a snap shift from 1st to 2nd and its out of tune and hasn’t been serviced in 4 months.
Anyway thanks guys
Posted: Mon Jul 26, 2010 8:04 am
by Daniel
Nice work Ashley!! always admire your work.
Posted: Mon Jul 26, 2010 8:26 am
Nice cams, should be interesting to see what she does on a dyno.
Posted: Sun Aug 01, 2010 5:55 pm
by Pinkfluffybunnys
As promised here are pictures.
New Throttle body
Old Throttle Body
Old VS New Throttle
Intake Manifold upper Plenum
Before porting
After porting
Install complete
Posted: Sun Aug 01, 2010 6:08 pm
by future sx owner
hay Ashely wen u gonna take ur new set up to talton 4 a run to see wat time it do now? let me kno wen u do go would love to see hows it run!!!
Posted: Mon Aug 02, 2010 6:22 am
by Pinkfluffybunnys
I was there on friday with the new set-up but only ran a 15.5 again
I did two runs (15.5 and 15.6)and both with allot of wheel spin, I just want to do a 14.9 and I will be happy.
Posted: Mon Aug 02, 2010 4:36 pm
by Lindt
if you had traction before the upgrades then normally after a power upgrade you have even less, so ye, you won't really go faster, exit speed might be higher though
