Engine choice
Info From Nico,
General
Pros
-its an RB! from a skyline!
-closest thing to a real skyline
-I-6 potential
-the awesome sound.
Cons
-Yes, it is more weight, around 150lbs more for a rb25 swap. the weight isnt important tho, its the weight shift. it really depends on engine/transmission and how you mount it (i.e. crossmember or aftermarket mounts), but realistically your looking at 2-3% overall weight shift. if you look at the numbers in a 3000lb car thats only a 60-90lb shift forward. just to put that in perspective, 12 gallons of gas weighs roughly 100lbs so there is more of a shift between a full and empty tank, than a RB swap. IT DOES NOT DESTROY THE WEIGHT BALANCE OF THE CAR
-Parts are still rare and expensive, but things are starting to come over
-mounts or crossmember swap required
RB20
Pros
-cheap
-skyline engine (?)
-WD-racing was saw near 400hp with his
-easy swap
-free revving up to 8k is possible on stock valve train
-excelent gas mileage off boost (it is a 2l after all)
-can make good power with minimal mods.
-sensors interchange with lots of usdm cars
Cons
-SR is easier with same potential (for your lower goal people). out of the box both will make near the same power, and upgrade easily to near the same numbers.
-cheap turbo (ceramic wheel)
-"weaker" tranny, nearly the same as KA/SR trans
-akward intake manifold
- its getting old 89-93 production years
-high mileage engines need proper mantinence ie timing belts and water pumps
- tiny injectors (270cc)
-intake manifold flange is diffrent from rb25 (greddy manfold does not bolt on)
-some rb20's can have the same problem as the early rb26 engines with the crank collar issue
RB25
Pros
-good potential (500+ on stock internals)
-VVT
-strong tranny (also include this when you price rb25s)
Cons
-expensive clips (when you get that strong tranny)
-becoming rare and expensive parts
-weak pistons ring lands
-not full glory as rb26
-another lame turbo, but better than the RB20's
-factory hp overrated (easily achieved with basic swap upgrades though)
-side feed injectors (hard to find)
-custom driveshaft required (unless you use RB20 tranny?)
RB26
Pros
-the GODZILLA of RBs
-most potential of all
-twin turbo stock
-upwards of 300+ out the door
-bullet proof
Cons
-r32 crank coller issue (kills motor)
-need for rb25 tranny
-hard to find r33 motors
-impossible to find r34 motors
-did we mention $$$$$?
RB30det hybrid
Using the higher displacement 3 L block from the RB30 engine mated to the RB25 or RB26 head can yield a very powerful engine. Here's a thread with details. http://forums.nicoclub.com/zerothread?id=188136
For Specs on engines and good info also check:
- http://www.meggala.com/nissanrb3css.htm
The RB25 crank is not FULLY counter balanced. The RB26 is.
My favorite part about the rb26 is that the entire motor will support over 425RWHP before any modifications need to be made.
This includes, injectors, mafs, turbos, and ofcourse all internals.
it also has internal throttle bodies which create better engine response
Stock bottom end has been taken to over 1000hp.
RB25DET is 9:1 Compression, better low end torque
RB26DETT is 8.5:1 Compression, bring on the boost baby!!
All RB motors are basically Factory Blueprinted. I love seeing the look on people's faces when I tell them that.
This Guys using a Z32 ECU to run a RB
http://forums.nicoclub.com/zerothread/3 ... -with-pics
General
Pros
-I-6 potential
-the awesome sound.
Cons
RB20
Pros
-cheap
-skyline engine (?)
-easy swap
Cons
RB25
Pros
-VVT
Cons
RB26
Pros
-twin turbo stock
-bullet proof
Cons
RB30det hybrid
Ok Ashley I appologise for the name calling it was childish, Im sorry.
The issue with your posts is youdont ever say why dont you do this or do that, you rather say thes a waste this is the best way. The problem is what is best for you isnt always best for everyone else, to me my Wolf system is better than your Nistune system but to you it is the other way round. Different strokes different folks.
Also you will post questions asking questions which we all give you the info you require but when we ask you a question or why you need that info, you NEVER reply. Why are you so secrative?? You are going for any records so why not help the rest of the guys out?? I think you have valuable info in that head of yours, but it is no good to us being in your head, share and help US out, its what the forum is meant for.
When you make a statement on the forum you are quick to back it up with full pages you have quoted from anyother site, If I wanted that info I would go there my self. By doing this it is implying that you dont know much and simply reguritate info you have read, for this I am weiry about taking your advice seriously. Rather explain your oppinions in your words and you will get FAR more credability for it.
My ranting is over, I will agree to disagree on the statement that the Nistune system is the best on the market for under R3000
This proves my point you are not reading or understanding what I am telling you, Your wolf system is a great system at no point did I attach it but for R 3300 rand you cant get one, installed and tuned can you?to me my Wolf system is better than your Nistune system but to you it is the other way round
But In my eyes Nistune or an emulator it is better then a dictator or a gotech, In both available information and ability to tune
But you not doing the R&D most of the continuing arguments can be avoided, Most the stuff I post goes against the grain of what been said so If I don’t back it up no-one would take it seriously not that they do anyway. Do you read most of the links I post?When you make a statement on the forum you are quick to back it up with full pages you have quoted from anyother site, If I wanted that info I would go there my self
Anyway back onto topic, It seems a lot of people are shifting to using the stock systems in swaps there are a number of guys that have installed RB25 and RB20 that have sourced there corresponding ECU’s through Ebay or other sites and then done the wiring using the factory pin-out tables then they would go with some type or real-time tuning board or emulator, It seems to solve a number of issues covered like they don’t need to weld on any trigger wheels ,change coils or change any type of sensor when swapping some have been able to keep nice function like fuel usage displays and cruse control. Also it seems to be cheaper then going with a Power FC or Emange system most commonly used in the states
