RudeBoy - 11.3sec 400m
- RudeBoy
- 0.5 Bar Boost
so, finaly got head done, and fitted... and between drags and driffts this weekend we actually managed to get some work done:
engine basically assembled:
want to fit clutch andbox and drop it into car this coming wednesday...
also got around to getting car onto stands, and to remove the clutch pipe to have a braided one made up, also got the walbro fuel pump installed..
want to bleed the brakes while the cars in this position, hence wheels removed, going to replace the brake fluid with bell-ray dot5 silicon brake fliud like i used on my KTM.... never managed to overheat that fliud in the bush - constatly using the brakes so i figure it should work pretty well in the car aswell- just expensive as f*ck at +- R300.00/ltr
- RudeBoy
- 0.5 Bar Boost
thanks Hanco,
Hey Riaan, thanks - motor was pretty good when we opened, it did need the oil pump drive as you suspected... will send you the results... got the new 4bar dicktator so we can boost more than 2bar when wanted or needed, by the looks of youor avatar you got the 2jz installed, hows it going?
regards
regards
- RudeBoy
- 0.5 Bar Boost
Got mine from Rezlo - shop offline at the moment but you could email him
or look at this link:
they have a sale on at the moment, but transport might be expensive, if you want let me know which one you want... and i can get you a quote - have dealt with them before:
http://titanmotorsports.com/nissan15.html
dropped the new motor and box in this morning, need to make a new gearbox mount... and then have the prop made, hope to have it done by next weekend... cant wait
