The bitch
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
Hahahaha ya ya
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
so clutch is pased its expiry date
seems the pressure plate is passed
was odd couz the clutch did not slip and i got gears easily
o well time for the car to stand again
![200SX_2guns [smilie=200sx_2guns.gif]](./images/smilies/200SX_2guns.gif)
Zookie_JDM
- Engine: 2JZ
- Real Name: Chelsy Pinto
Re: The bitch
HURRY THE F UP!!!!
2010 Suzuki Swift Sport ZC31S
1996 Mazda MX5 NA18P
EX: 1991 Honda CRX ED9
EX: 1994 Honda Ballade SR4
EX: 1992 Nissan 200SX S13
EX: 2008 Suzuki Swift ZC21S
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
Yes boss. Hahahahahahaha. Waiting on funds as usual....Zookie_JDM wrote:HURRY THE F UP!!!!
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
So where to start hmmmm
Pulled the motor out on friday was easy with the box already out.
Found a lose waste gate. That was a shit 1 to tighten up.. Bent a 10 spanner passed any recognition.
The fly I should be getting later 2day..
Rear oil seal is swapped. Cleaned out the sump so its nice and clean.
Saw I got a burnt harness going to the headlight fuse box. At least it was only the old ecu wires that were burnt so all is good and the rest is hidden from the heat of the turbo and mani...
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
so over the long easter week end i was doing this
pulled the motor out to swap out the rear oil seal and pull the flywheel off
forgies still look shiny
found where she was breathing oil when it was under boost. such a kak spot to find with the motor in the body
the car has got a friend to keep itself company when im not working on it
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
so time to update 1 mm of dust and counting
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
ok been a long time since ive up dated dam where to start
so clutch. got one made up by Hannas at the track
i replaced the gearbox oil seals to have one fail on me not sure why it did but had to pull it out again
got all running and found my radiator cap leaking. think that must have been the easiest thing to fix
cleaned up all the wiring in the car
then coming home from the track i found i have some smoke comming from the engine bay..
dam turbo oil seals went on it. Was leaking out the housing and dripping onto the manifold. when i got home it stopped but i decided to take it all apart anyway..
and i got a nice hole in intercooler. will see if i can weld it up... even for a temp till some founds come in
just my luck hey
just my luck hey
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
gone weld a plate on it covering it up.. just wana clean it up a bit 1st
Re: The bitch
Damn man....I thought I had bad luck...
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
Hahahahaa yea man. Ag shit happens
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
ok so got a new turbo t3 t4. rather large compared to the old turbo but im gona take this bad boy to a bar and she what shes like for my driving..
old vs new
car went on a diet plan agin hahaha, all is out now just need to pull the carpet out. Will cage her up in dec when i have some time to do so
so got my hands on these. decided they looked boring, so painted them. didnt stress about the paint on the rubber couz the rubber wont be on them for long
thinking of doing the all like this...
old vs new
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
So haven't done much to her in a long time.. Just been sorting out other shit.. Basically the intercooler is welded up.
The cars was stripped out all sound deadening was removed. Its been painted white on the inside just to clean her up abit till I sort out the cage.. Um turbo is on and that's about all of it..
Re: The bitch
Ades, I will probably wear my car out and die before you get this thing arolli`n again !!!
Comeon boyo, get her running !!
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
Yea I know its bad to think how long she's been standing.... Will try start her on the weekend
