LSD diff or not?
- phoenix s14
- Car: S14
- Real Name: Mark Appelgryn
- phoenix s14
- Car: S14
- phoenix s14
- Car: S14
seriously the propshaft will be locked but you will have only the diff working. hence the non viscous gear diff will just spin internally with no brake but the viscous diff will try to brake the effect (slip).
(dont try this at home) - if you jack up one wheel and start the engine and engage a gear and it does not pull off the jack then you have a normal diff...
if it does go to hospital and you have a LSD...
I like my church test better...phoenix s14 wrote:seriously the propshaft will be locked but you will have only the diff working. hence the non viscous gear diff will just spin internally with no brake but the viscous diff will try to brake the effect (slip).
(dont try this at home) - if you jack up one wheel and start the engine and engage a gear and it does not pull off the jack then you have a normal diff...![]()
Captain Slow to the rescue!
mashing gears covered in oil get hot. keeping it cool is not a bad idea!
is there any evidence that its been opened?
do the test man - either do a burnout/donut and look for 2 stripes, or jack up the rear and make sure the wheels turn in the same direction!
300ZX 84-86 MT and A/T (3.7) (R200)
300ZX 84-86 Turbo MT and A/T (3.54) (R200)
300ZX 87-89 MT and A/T (3.9 ) (R200)
300ZX 87-89 Turbo MT and A/T (3.7 ) (R200)
Note Turbos:
#1) after 4/87 only-(3.7 Clutch Type LSD)
2) 88 All White SS used a 3.7 Viscous Coupling LSD)
3) LSD Unites Came With Finned Rear Covers
Note Turbos:
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
