rev counter
				sideways precision
- Newbie
rev counter
hi guys wanted to know if anyone knowz how to check my rev counter as it goes bonkers while im driving or idling can anyone assist. I have dictator management t3/t4 turbo external wastegate 550 injectors intercooler uprated fuel pump and extremely upset that my rev counter not working
				Ero_sennin
what u mean bonkers?
does it jump around alot? Then its not getting the correct signal(voltage) from the diktator? you might need to add a resistor between the tator and your rev counter to get the correct voltage.
Any one else with a dicktator care to comment?
SONY Xplod inside
SR20DET Powered Red RS13
				sideways precision
- Newbie
i just installed a gotech pro with my sr20det.
the gotech has a rev counter output wire, which i wired straight into the s13 rev counter pin on the white plug near the original computer box. no hassles so far.
doesnt the dicktator have a similar output wire for the revcounter?
- poizen
- Real Name: Mical Mackay
veecee wrote:i just installed a gotech pro with my sr20det.
they do well the one in my golf does i think it red or orange
				sideways precision
- Newbie
sounds like you have some work to do their bud.
your best bet? ask riekert for some assistance. he's also just done the sr20det swap into his s13, and he become well-versed in the intracacies of the s13 cluster wiring system!!!
the reason i suggest him - he lives in hermanus, quite close to CT then!
- poizen
best to do it yourself go find the white wire and then find the wire for the dicktator i take it you have the wasted spark if so here the wiring diagramsideways precision wrote:still have ca18det motor
http://www.dicktator.co.za/downloads/Di ... arness.pdf
no dude...
if you're wired into a white wire for the s13 cluster rev counter, then you're doing it wrong.
its a yellow wire you're looking for, iirc. and its on a white plug, near the stock ecu location. you'll have to remove the glovebox to find the plug.
VC is correct. Its a yellow and red wire that give the signal to the tach. It might be that ferolli when they fitted the dicktator screwed it somehow. With the SR conversion I had to wire in a resistor between a live 12v and the rev counter signal wire to get it working right.
If not try and run it to the Rev signal out on the diktator to the yellow/red on the cluster.
Like VC said, you'll find the cable on the white plug next to the cubby hole.
Hope it helps....
Hope it helps....
