got via email, probably on its way to you if you havent seen it :
i will put the pix up just now...
Another invention the Indian fellows will go nuts over
> >> Radurra is Italian for Clear
> >> The creator and patent holder of "the clear wheel" Doug McGoon and
> >> Forgiato have combined to turn this idea into a real drivable wheel.
> >> In 2006 we proudly produced and introduced "The Clear Wheel" called
> >> Radurra for cars and motorcycles.
> >> Again we return to our roots of jewelry manufacturing. A technique
> >> known as bezel setting which only master diamond setters can know, is
> >> where the diamonds are just slightly larger than the bezel they ?
> >> are set
> >> into, and held in place by pressure. Understanding this, we put the
> >> same care and consideration towards the Radurra as we would towards a
> > fine watch.
> >> By eliminating the alloy center of a three piece forged wheel and
> >> setting into its place a hard coated polycarbonate center with a
> >> glass-like finish we achieve an amazing and stunning look, with a
> >> finished product that looks too good to be a wheel. Much the same way
> >> the diamond is set into a bezel setting, the polycarbonate center is
> >> set into the forged aluminum hoops with precision machining and a
> >> jeweler's touch... the end result is a wheel that is strong, safe and
> > beautiful.
> >> Now show off your high performance brakes and suspension on your
> >> high-end car or motorcycle. The same way you would add diamonds to ?
> >> your
> >> platinum watch, add the Radurra to your "platinum" car or custom
> >> chopper. With a vast range of color and finish options, your ?
> >> Radurra is
> >> sure to be as individual as yourself or your clientele.
> >> The Radurra is currently available in twenty and twenty-two inch, and
> >> are custom built on order for your car or motorcycle.
> >> ??The same way all Forgiato Wheels are custom built by master
> > craftsmen.
> >> ????????????????????????(More sizes available soon)
> >> ??????????????????????????????Technical Data
> >> ??The center is 1.5 or 2" polycarbonate, chemical hard coated both
> >> sides.
> >> ???????Weight 20" - 27 lbs, and 22" - 38 lbs (complete wheel weight)
> >> ??????????All other parts of the wheel are forged 6061t aluminum
> >> ??????????????????(Inner and outer hoops and Hub center)
> >> ???SAE tested, certified and passed Impact, cornering and radial
> > tests.
> >> ??????????Now in production, average delivery time is 6-8 weeks.
> >> ??????????????????Suggested retail is $5000.00 per wheel
got via email
- widowmaker
- Real Name: Walter
- widowmaker
- Real Name: Walter
- widowmaker
- Real Name: Walter
- widowmaker
- Real Name: Walter
another email
How to get home on a Friday ...fast.
Tired of speeding tickets?
Want to open up spaces between you and the cars around you.
Step 1. Tie these balloons to your car
Step 2. Drive VERY FAST
Step 3. Watch people freak out.
Step 4. Tell the nice officer you thought they were real.
