sum advise needed
poizen
Real Name: Mical Mackay
sum advise needed
Post by poizen »
hey guys i need some advise i want to get rid of mu coils and put a single msd ignition module with plug leads what do i need to do this will i need after market management or not and what msd should i use or is there a better one
poizen
Post by poizen »
has anyone done this mod
Doctor G
0.7 Bar Boost
Post by Doctor G »
Spitronics makes a single coil with 4 plug lead outputs. Also look at the ford fiesta/focus rocam coil. They're round about a grand or so.
You will need to wire the coil up using the wires from your ingition module / ignitor, and you will still need the CAS to supply the signal as to when the coil must fire.
I haven't actually done this but that is how I see it.
Speed breeder
0.7 Bar Boost
Post by Speed breeder »
i've done this, but running gotech - you're still on factory management. contact louis at Gotech, they sell single unit coils for R650 - see their online shop on their website.
Enquire if this will work on the original management - I doubt it... but worth a try...
http://www.gotech.co.za/catalog/product ... 4a6pmsa847
