Clutch
Clutch
Jayboy and Vlade, I think you have replaced your clutches a few times, My clutch was replaced but is very soft now, too soft, it has been bled at the booster and at the bottom, what to do I don't like the soft thing.
Thanks for the input guys, I'm sorted.
What was the problem??
Vlade
* - Club Pimp - *
Real Name: Barend
Post by Vlade »
I think he found he needed to bleed it at the damper and the slave cylinder... :?:
I removed my damper all together... now my clutch is as hard as a rock
Hairdresser MX5
We replaced the clutch selynder kit that I got from auto zone, the clutch was harder but did not want to return properly, then after speaking with Jonathan he said there must be a return spring on the pedal, after short of accusing the guys that did the clutch of remooving the spring went there and we searched for a spring but coulden't find one.
He had an old boks shape sentra hatch body there so with the notion that most of these parts are used in standerd places I checked the body and found the spring, put it in but the clutch would still not properly return.
Then we took out the master celynder kit and found that the replacement one was not working properly so we put the old one back again and it worked but is still softer than it was before I did the clutch, will need to get a kit from nissan and do it all again. At least it's working properly, I can feel the clutch is gripping again and the power can now actually get to the wheels.
