A very good mate of mine is selling his D1 race car. 2JZ
Ready to race!!!
Specs:
Trust surge tank
Infinity throttle
TRUST T78-29D turbine
Front pipe muffler
HKS cam shaft IN264 OUT272
HKS strengthen timing belt
SARD [delivery pipe injector 850CC fee El regulator collector tank (265L × 2-in pump)
HPI [intercooler (and again pull pipe one-off, Aluminium radiator (Suparu electric fan 2 aircraft)
Kazama Auto power steering cooler
Virion power steering tank
SARD Radiator reserve tank One-off water bypass TRUST aluminium pulley
Kazama Auto (engine mount & Mission mount)
Body
Professional mode D1-SPEC Aero(FB/SS/RB/FF/RF)
M Sport carbon under diffusion-user
M Sport carbon canard
MSports carbon bonnet
Freestyle carbon GT wing
RASTY carbon door [left and right]
HPI acrylic window (front normal)
Ganadoru Aero mirror (full carbon style)
RAYS 57 Ultimate 17 × 9.5J + 12 red × 4
Spot widening around strut
Kazama Auto tow hook GT version (front and back)
F1 type rear LED
Wise Square LED tail lamp
Art Factory Vinyl graphics
Power trainDG-5 fu Coulter pu-height
Swift spring F12K R8K3UP front upper mount
Kazama Auto
Pirro tension rod Ver2
Kazama Auto rear upper arm
Kazama Auto traction rod
Kazama Auto HICAS stopper rod
Kazama Auto strengthening tie rod
GP Sports Super knuckle
KITTOMEI Technical Tracks Advance LSD(Final 4.1R) BCNR33
BCNR33 genuine Drive shaft
BCNR33 genuine Propeller shaft
JZX110 genuine 5-speed transmission
ORC metal twin clutch
Endless 6POT caliper & rotor
Proportioning valve (redrawing full brake line)
Electrical, interior
HKS V-PROHKS EVC5Harness
DEFI BF Advance meter (water temperature oil temperature oil pressure)
Virion fan controller
Battery in the trunk relocation Battery case (regulation correspondence)
JZX100 genuine meter transplantation (to take the vehicle speed)
Main pump & collector tank independent switch
Outside blower fan
One-off water spray three places (trunk in 20L)
Saito roll gauge breaks one-off roll bar
BRIDE Zita (Driver's seat, passenger seat)
HPI 4-point harness × 2 green
Narudi 34 steering
La fix removable handle boss
Fire extinguisher
Driver's seat power window
Passenger seat and (fitted kill)
Four rear acrylic glass air vent hole(By D1 regulation)
Idle because the controller is not
Control is required in the accelerator when you start the engine
Idling stable after you warm.
Price R365 000
Let me know and I will put you in contact with him
Kazama Auto D1 S15 Race Car
- 0.4 Bar Boost
- 0.4 Bar Boost
- GameBoy
- Real Name: Roscoe
Re: Kazama Auto D1 S15 Race Car
Somebody loan me some money!
hahaha that face ^^^
