Project Robldepo (for now)
- 0.2 Bar Boost
- Real Name: robert
Re: Project Robldepo (for now)
wil post some pics of the setup as it is in the car as soon a s i get the car to start. for some reason i have no spark so there is just loose wires and tools laying all over the show. its driving me in sane not knowing what the problem is
Looks awesome!! Just out of interest did you try and turn the steering wheel lock to lock after installing the front shocks? The reason I ask is the shock mount needs to go onto the shock in a certain position or the shock catches on the wheel well.
- 0.2 Bar Boost
- Real Name: robert
yes J i did that they turn just fine.
hey guys spark is sorted now yeah. the write up that i followed to do this swap didnt mention anything about the thick blue wire in the white plug next to the ecu plaug known as plug F1. this wire gives ign 12v to the coils and it wasnt used according to the writeup but its sorted now and the car starts. just need a new radiator now as i noticed mine is leaking badly. thanks J for pointing me in the right direction regarding spark problems.
- GameBoy
- Real Name: Roscoe
Nice!
Out of interest how much did the radiator and fans set you back? I need to do that change sometime soon.
- 0.2 Bar Boost
- Real Name: robert
radiator was R1850.00 at MR Turbo fans i got from Armand but they go for about R600 each i could be wrong. MR Turbo also sells them
just burnes my arse that a brand new radiator already has bent fins and i would make a move real soon dude they only have 2 radiators left.
- 0.2 Bar Boost
- Real Name: robert
please take not the boost pipes look like crap but its a tempry messure untill the car is running proper then ill install cooler and build proper boost pipes
- GameBoy
- Real Name: Roscoe
Cool, thanks.
- 0.2 Bar Boost
- Real Name: robert
at last i got the rev counter working, now im down to fitting the bonnet the boot lid and the light covers, then i can take it for wheel allighnment. And pray there is nothing else i have to do accept for fine tuning. once the car is running 100% i can start withe cooler and some more goodies and guages.
- 0.2 Bar Boost
- Real Name: robert
howsit all
ive made some changes to my build and would like to share it with you guys but for the life of me i cant remeber how to share pics. can someone please give me a crash course again?
thanks
thanks
There is a file attachment section in you normal reply or you can use a image hosting site like photo bucket
