Oil change
- Calvin S13
Oil change
What oil can I use , I have a bottle of Hx7 and Helix plus but it isnt full synthetic , I am going to track my standard 1991 200sx
Any advice?
I also need parts for it , I live in durban south africa
Any advice?
Re: Oil change
what oil is in the car currently?
- Calvin S13
Re: Oil change
I have no idea I just bought the car last weekend and it needs a oil change soon
Re: Oil change
Need to find out you cant mix mineral and synthetic
- Calvin S13
Re: Oil change
I will drain it and put new oil in
Re: Oil change
Need to flush it if u changibg from mineral to synthetic and VV
- Calvin S13
Re: Oil change
But what should I put in ?
- Calvin S13
Re: Oil change
Can I put hx7 or helix plus ?
Re: Oil change
I use shell helix ultra fully synthetic, been running it about 3 years and never had a problem, motor is brilliantly clean inside, although i service it alot even though I've only put like 8000km on it in 3 years
- Calvin S13
Re: Oil change
Okay cool
- Nissan_Fanatic
- Real Name: Henco
Re: Oil change
+1 on the Helix Ultra, but it's become really expensive the last while.
I now run Indy Oil Syntro 5W40. Fully synthetic oil and really cheap! Been using it on my freshly built engine (after break in) and
even my wife's Almera and no complaints so far.
Btw, do some research on the mineral with synthetic mix. You are allowed to mix the two (that's what they do with semi-synthetic oils like
Shell Helix HX7), but try not to mix different oil brands as some of the additives can fight each other and/or cancel each other out...but don't
take my word for it, do some research, its actually very interesting
Hope this helps
Hope this helps
I like all cars, I just like some more than others
'93 Nissan 200SX
Ex: '93 Nissan Sentra 160GX - SR20VE
'93 Nissan 200SX
Re: Oil change
Yup hx7 is semi synthetic, i use that is my mom's Almera and would even recommend it for an sx but the ultra a better choice, my friend works for shell so i get slight discount on shell stuff so i havnt tried other brands yet, Castrol edge is also good i hear, Mobil is a bit over priced i think
