CA18DET Forged rebuild
- mario_200sx
Re: CA18DET Forged rebuild
Start will no boost and slowly build from, it's now at 0.55.
You need the high rpm to increase the wear on the rings, also running back against compression will help set the rings in the grooves. You must go to redline in order to wear the honing down, if not you can create a ridge.
Just did leakdown test, results as follows after only 200km:
Cylinder 1 - 10%
Cylinder 2 - 9%
Cylinder 3 - 12%
Cylinder 4 - 11%
These results prove break in procedure worked...
Cylinder 1 - 10%
Cylinder 2 - 9%
Cylinder 3 - 12%
Cylinder 4 - 11%
Meth tank in, pump mounted.
- Newbie
- Real Name: Stan
so neat and clean
So I ordered an eccentric throttle wheel from GKTech in Aus, was delivered in 6 days of placing order on the cheapest shipping service, brilliant.
Problem is it does not fit. The slot in the center is 90 degrees out so the cable does not fit. So I drop them a mail and after a few emails back and forth their attitude seemed to have changed and I was told the throttle body is incorrect and the wheel is correct. No where on there site does it say that the wheel would only fit certain throttle bodies...
Anyway I would not purchase anything from them again of any decent value in case my car is wrong for the part...
Here a few pics...
Here a few pics...
- DriftZ
- Car: S15
dont say i didnt warn you ...lol
Put it in milling machine and machine slot correct, will check tonight if it fits.
