Z32 brakes
Z32 brakes
Hi guy what will i need to change to do this upgrade and how much does a conversion like this cost?
- Drillergy
- Real Name: Darryl
Re: Z32 brakes
Im busy with this upgrade.
Im only doing the fronts though.
Its basic bolt on.
You will need...
Calipers.
Seal kit if it was not used for a while
check pistons, replace if pitted
S13/Z32 braided brake lines
Murano disks re drilled to 4x114
and that should be it.
Make sure all pins, anti rattle clips and stuff is on the calipers.
Its basic bolt on.
You will need...
Calipers.
Re: Z32 brakes
thanks dude how much has it cost you?
- Drillergy
- Real Name: Darryl
Re: Z32 brakes
Hey man it cost me around R5.5k.
but you can get I done for around R3k
- nirvash
- 1.0 Bar Boost
- Real Name: Andreas
Re: Z32 brakes
like said here, its simple bolt onDrillergy wrote:Im busy with this upgrade.
Its basic bolt on.
You will need...
Calipers.
costing me atm R5k for front and rear calipers and used disks,
just need to get s/s lines and pads now, possibly rebuilt kits to
Current. CA18DET S13
Re: Z32 brakes
Where are you getting front & rear calipers and discs for R5k?
- rat
- Car: R32
- Real Name: Rat
Re: Z32 brakes
+1Enzio wrote:Where are you getting front & rear calipers and discs for R5k?
- nirvash
- 1.0 Bar Boost
Re: Z32 brakes
from white fang on the forum, of his skyline i think, got the fronts and look in good condition, just need to pay for the rears stillEnzio wrote:Where are you getting front & rear calipers and discs for R5k?
