Wierd noise need help
Got a company? Does it have valuable services for our members? then post it here
Calvin S13
Post by Calvin S13 » Wed Oct 08, 2014 3:56 pm
I have a clucking noise coming from the front left when I apply brakes , it is as if something is moving forward , but nothing is.The wheel also moves a bit when I brake.There is also a ticking noise when I move the steering wheel from left to right quickly like shake it
Please help guys im racing soon and I need to get this car right
Re: Wierd noise need help
Post by SonOfAnarchy ZA » Wed Oct 08, 2014 4:22 pm
check if everything is tight but does sound like a worn bush on one of th suspension parts
Enzio
Post by Enzio » Wed Oct 08, 2014 5:13 pm
Check all your suspension mounting, steering links and wheel bearings.
If the wheel "moves" I would suggest you stop driving the car immediately until you find the cause
Calvin S13
Post by Calvin S13 » Wed Oct 08, 2014 5:19 pm
The wheel only moves a bit under braking and only once so when I apply brakes I hear it clunking.I was told it was my lower control arm bushes and my cv boot
Calvin S13
Post by Calvin S13 » Wed Oct 08, 2014 5:20 pm
I was just checking if it could be something else
Enzio
Post by Enzio » Wed Oct 08, 2014 8:10 pm
Front left?
CV boot?
You are in good hands
Post by Charlvdw » Wed Oct 08, 2014 8:53 pm
Enzio wrote:Front left?
CV boot?
:D
I would just replace all the bushes with poly.
Calvin S13
Post by Calvin S13 » Wed Oct 08, 2014 10:10 pm
Okay thanks
