Hi guys My motor is shot and in need of a new one or working one at least.
Any one know where i might find one ?
Thanx
Drivers Side Power window Motor
- 0.2 Bar Boost
- Real Name: robert
Re: Drivers Side Power window Motor
did you manage to find one yet?
No buddy but I checked the window again and it might be stuck. Have to remove it to confirm.
But I am lazy to do it.
I probably will have make some time.
I will have one in a few months when my carbon doors arrive.
- 0.2 Bar Boost
- Real Name: robert
ok well if you dont come right im sure i have one
Hey bud would a S13 motor work on a S14 window? I would be interested iff it does and if you want to sell
Ok guys it's almost midnight but earlier today I removed the whole mechanism and window.
I fiddle with it and it worked fine
So I service the mechanism and check cables so on never opened the motor.
Put everything back worked twice and stuck again.
So tomorrow I will remove it again and update on this.
Thanx guys I will shout when I need the motor or so if it needs to be repaired.or replaced.
Sent from my E5303 using Tapatalk
- 0.2 Bar Boost
- Real Name: robert
MarcoSX i suppose the only way to see if the motor will work on s14 is if we compare the 2 motors
Ok update on the window status on the sx.
It appears it gets some way miss aligned going up.
So I left out the stoppers stopping it going to far up so that the Window prevents the door from closing out. And also partially lose the whole mechanism but not so much so the window will shake and brake. I will continue to monitor it as time goes by.
But all seems wel now.
