Over fueling or Injectors or Something else
Enzio
Re: Over fueling or Injectors or Something else
Post by Enzio »
Those are stock injectors.....harness connectors are normal Bosch EV1 type and can be bought at most parts shops
Jaco1981
Real Name: Jaco
Post by Jaco1981 »
Enzio wrote:Those are stock injectors.....harness connectors are normal Bosch EV1 type and can be bought at most parts shops
Awesome, thank you very much!!! :D :D
PS, what is this item for?
Ex: 1985 Alfa GTV 2.0
Ex: 1981 Alfa GTV 2.0
Ex: 1989 Honda Ballade 160i DOHC
Ex: 1991 Honda CRX
Ex: 1997 Honda RVF 400
Ex: 2007 Yamaha R6
Current: 1991 Nissan 200sx
Dumpvalve for realising the pressure in the boost pipes so so the turbo doesn't surge and get damaged
Enzio
Post by Enzio »
It makes a stupid noise and makes your car run poorly ;)
Common ricer mod on these cars, it might even be part of the reason for your idling issues.
I had one on my car that leaked under vacuum (idling)
Jaco1981
Real Name: Jaco
Post by Jaco1981 »
SonOfAnarchy ZA wrote:Dumpvalve for realising the pressure in the boost pipes so so the turbo doesn't surge and get damaged
The thing is this. That blue line is not connected to anything, its just hanging there.
The pic below, is from another angle, just before the intake, is a dump valve that is hooked up?
So is it safe to say, that might be an old dump valve that is not working anymore?
PS, is it normal for this setup to have the waste gate on the turbo itself welded shut?
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
Enzio
Post by Enzio »
Wastegate welded shut?
Does it have an external wastegate? (I cannot see one in the photos)
Since the previous owner left a redundant dump valve there I am starting to see what kind of car you bought.....hope you get it sorted and do a better job than the previous owner.
Jaco1981 wrote: PS, is it normal for this setup to have the waste gate on the turbo itself welded shut?
No its not, do you have a pic of that?
Jaco1981
Real Name: Jaco
Post by Jaco1981 »
I was aiming for a stock one, but gave up after a few months. This one is not to far gone, well, it looked that way when I bought it.
Charlvdw wrote:No its not, do you have a pic of that?
Think that might have been a false alarm. Will confirm it when the injectors are back in
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
Only reason one would weld the wastegate closed is if u using a external wastegate but that's not the best move send more pics
Jaco1981
Real Name: Jaco
Post by Jaco1981 »
Ok, so I took the injectors to SAC, they advertise on their website, that they can refurbish injectors. They then told me that they need to send it to JHB. So eventually we spoke on Friday, they said they cant repair it, its to far gone. I'm a bit confused, but ok.
Do you guys know any other places around Cape town that can have a look at injectors?
I saw on Facebook a guy somewhere upcountry, breaking a SX. Contacted him. Sold me the injectors, fuel rail and regulator. Made payment today and waiting for it to arrive. Hope they are in better shape!!
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
Enzio
Post by Enzio »
Go to your nearest Bosch service centre. They do the ultrasonic cleaning, flow testing and repairs.
Jaco1981
Real Name: Jaco
Post by Jaco1981 »
Enzio wrote:Go to your nearest Bosch service centre. They do the ultrasonic cleaning, flow testing and repairs.
Thank you very much, will do that once my set have been returned.
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
Jaco1981
Real Name: Jaco
Post by Jaco1981 »
Ok, so the injectors came, turn out to be the wrong injectors, and dont even fit the rail :facepalm:
So, moving on. Does anyone here have a set of stock injectors they want to sell?
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
I have a set they need new o rings
Jaco1981
Real Name: Jaco
Post by Jaco1981 »
This is so strange. The guy I took my injectors to, phoned me now and told me, he had the injectors at 6 bar and it did not drip, according to him, they are not in bad shape and only need a good cleaning. He also replaced the caps (those caps on the manifold side. Will have them back by Friday.
So now, the question is this, how does the petrol get into the oil? If its not the injectors dripping and the motor is not overfueling...... :?: :?: :?:
Ex: 1991 Honda CRX
Ex: 2007 Yamaha R6
