Re: Engine just Died !!(Solved)
SMKNG ACE
Post by SMKNG ACE »
Ok here goes.
Not sure what it is or caused it.
My sx with CA18DET just died while driving. i think i heard a rattling noise just before that and it lost all power.
It sounds like the engine got no compression at all when turning.
Oil is good , fuel good, water good and temp normal at time of incident.
Car got no big mods just bigger intercooler and exhaust rest is stock.
Any input appreciated.
Maybe it is time for a decent rebuild.
Thanks in advance
Check your compression first dude.
SMKNG ACE
Post by SMKNG ACE »
yea gonna have a look when weather is clear as it is raining cats and dogs here. and no garage atm
check if your cam belt snapped, couldve snapped and bent valves, thus now no longer have compression and wont start
SMKNG ACE
Post by SMKNG ACE »
ok guys cars engine seems ok valves fine cambelt fine plugs great.
AND i have decided to pull the engine to overhaul and fit my branches and new turbo after rebuild on engine .. now i need to budget for all the overhauling parts.
Thanx guys but i have no clue what it is and will have to pull the engine and open up to see.
But first i have a shoulder operation and then only i will pull the engine. When i have both my arms working again.
[smilie=200sx_200sx.gif]
Before you pull you have to make sure it's mechanical, otherwise you redo the engine and it still doesn't start
Draco wrote:Before you pull you have to make sure it's mechanical, otherwise you redo the engine and it still doesn't start
Ja I agree!
Your CAS might have just kaked or something. what ecu fault codes are you getting?
SMKNG ACE
Post by SMKNG ACE »
I will make sure guys Thanx .
make sure you got
fuel pressure
spark
compression
CAS trigger
your temp sensor is working and still plugged in
injectors pulsing
proper ground
working battery
no ecu fault codes
If you need help to diagnose any of the above just shout
SMKNG ACE
Post by SMKNG ACE »
I will shout when needing help. But for now I am in hospital visiting the butcher.
Fuel pump fuse?
SMKNG ACE
Post by SMKNG ACE »
Already checked it working perfectly
GameBoy
Real Name: Roscoe
Post by GameBoy »
Good luck with the op...
SMKNG ACE
Post by SMKNG ACE »
Thanx Gameboy. Much appreciated buddy.
