Page 2 of 2
Posted: Wed May 28, 2008 12:12 pm
EightySix wrote:
Stay tuned for the next chapter : Body Parts !!!
Only Available from
Droomers Nissan
021 870 3135
Jean
WhoooHoo!!
Posted: Sat Aug 16, 2008 7:51 pm
Std s13 Brake pads
Midas / Autozone
ATE AG589 - Front R390
ATE AG590 - Back R264
Posted: Fri Jul 24, 2009 11:59 pm
by Speed breeder
Part numbers for clutch master and slave cylinder pistons, rubbers and springs from MIDAS - manufacturer is Motopart
IMT7689M - R30 Dec 08
IMT791M -R20 Dec 08
Gearbox seals and gasket from Nissan OEM (special order)
Gasket behind front cover 32112V5001 = R12.85 excl
Oil seal front in front cover 32114Y4000R = R65.25 excl
Oil seal rear (propshaft) 32136U0100L = R26.75 excl
refer img
Posted: Sat Jul 25, 2009 12:43 pm
by Drillergy
Thanks SB. Probably gonna need mines done on monday. How long did it take to order from Nissan?
Posted: Sun Jul 26, 2009 10:43 am
by Speed breeder
Ordered it at 14h00 on Tuesday, got the phone call from North West Nissan in Princess 15h00 on Wednesday.
Posted: Mon Jul 27, 2009 8:04 am
by Speed breeder
8 port head intake manifold gasket = JC978 = R34 Midas
Exhaust gasket (per port) = JC788 = R12 each Midas (need 4)
Posted: Thu Aug 13, 2009 7:27 am
by Speed breeder
Original pressure plate Nissan C021038F09 - R1533
Posted: Thu Mar 03, 2011 6:41 am
by BigKriss
For the RB guys with a slipping alternator belt.
Nissan Part # 11720 v 7300 micro belt 4g x 863mm.
Used on the RB20 and works perfectly on the RB25.
R197.40.
Posted: Fri Mar 04, 2011 2:28 pm
by Grobblere
Taken from CA18DET.org
If you are looking for parts, tell the autoparts store that you have an 88' Nissan Pulsar NX SE. It will be the correct part 99% of the time!
Oxygen Sensor CA18ET 200sx Bosch 13276 $47.99
Spark Plugs CA18ET* 200sx NGK PFR6A-11 $Varies
PCV Valve CA18DE Pulsar NX Bosch PCV142 $2.99
Thermostat CA18DE Pulsar NX 491-180 $4.99
Thermo Gasket CA18DE Pulsar NX Felpro 35228 $0.89
Water Pump** CA18DE Pulsar NX B150-1350 $33.99
Upper Rad. Hose KA24DE 240SX L-564 $7.99
Lower Rad. Hose KA24DE 240SX M-563 $7.39
Oil Filter CA18DE Pulsar NX Bosch 3400 $5.49
Alt Belt 4pk855 $9.99
PS Belt 4pk845 $8.99
AC Belt 4pk840 $8.99
* Exhaust side needed
** Includes Gasket
Other Spark Plug Options:
PFR6/BCPR6's for standard (gap of 1.1mm)
PFR7/BCPR7's for lightly modded (gap of 0.8-10mm - see what works for you)
BCR8's for high boost applications. (gap 0.6-0.8 dependant on boost level)
Oil filter 15208-H8911 Ryco Z386 or Ryco Z145A
Door bump rubbers 01658-J7000 (Skyline R31)
Exhaust manifold gasket 14036-D4200 (EXA 1.8, S13 CA1 Four separate pieces
Intake manifold gasket 14035-D5710 (CA18 all) Injector rail to cylinder head
Intake manifold gasket 14035-D5711 (CA18 all) Injector rail to intake runner
Intake manifold gasket 14035-53J10 (SR20 all)
Turbo inlet flange gasket 14415-75F10 (200SX)
or 14415-17M00 (S13 all) The Aust 200SX one fits.
Turbo outlet flange gasket 14445-26E00 (S13 all)
Engine front oil seal 13042-42L00 (CA18 all)
Engine rear oil seal 12279-18V00 (CA18 all)
Oil pan seal front 11121-01F10 (CA18 all)
Oil pan seal rear 11121-01F15 (CA18 all)
Head gasket 11044-51E00 (CA18 all)
Head gasket 11044-50F00 (SR20) until 9/92
Head gasket 11044-50F01 (SR20) from 9/92 till 7/93
Head gasket 11044-50F10 (SR20) from7/93 onwards
Engine gasket kit 10101-51E25 (CA18D) Engine rebuild gasket kits
Engine gasket kit 10101-56E25 (CA18DET)
Engine gasket kit 10101-50E25 (SR20DET)
Engine gasket kit 10101-51E26 (SR20D)
Flywheel Bolts 12315-55M00 $2.18
Valve grind gasket kit 11042-51E25 (CA18 all)
Valve grind gasket kit 11042-50F25 (SR20 all)
Fan belt 11720-V7301 (CA18 all) L = 855mm
Fan belt 11720-52F00 (SR20 all)
Compressor belt 11920-V7301 (CA18 all) also suits power steering pump
Compressor belt 11920-30R10 (SR20 all) also suits power steering pump
Water pump 21010-V5528 (CA1 until 8/90
Water pump 21010-V5529 (CA1 from 8/90
Water pump 21010-52F00 (SR20 all)
Thermostat 21200-V0201 (CA18 all) 82.0 C
Thermostat 21200-V0206 (CA18 all) 88.0 C
Thermostat 21200-53J00 (SR20 all)
Radiator cap 21430-01F01
Radiator hose - upper 21501-35F10 (CA18 all)
Radiator hose - lower 21503-35F00 (CA18 all)
Radiator hose - upper 21501-52F00 (SR20 all)
Radiator hose - lower 21503-52F00 (SR20 all)
Bonnet bump rubbers (large) 62840-D0100 (Skyline R31)
Engine coolant 10120-89904 Castrol
Dash switch back lights Nissan Aust, have similar types
$11.00 each **** Smith P8130, with fiddling needed or 12v lamps WT2-12 from WES Components, good fit. 65c each
Radius rods (Tension rods) 54468-35F20 (S13 all) includes bush Genuine Nissan imports (JSVA), Remanufactured with Urethane (Cars of Saigon ).
Wheel nut 62840-21001 (R31 Skyline)
Brake pads See service info page. Bendix and others.
heater hose w/valve part 02-0036 or p/n ch1649 same as 1988/90 holden commodore 3.8ltr
(needs to be cut slightly)
Headlight globe Who cares Any brand. H4 60/55W 12V or H4 100/55W 12V the second one has 100Watt high beam.
Rear Dampers
( shockers ) See Nissan Dealer or Nismo KONI. Part no. 80-401-081 sports kyb.
Approx $315 a pair.
Fuel filter 16400-F5100 (CA18 and SR20) RYCO Z202 or Z201
Air Filter 16546-V0100 (same as R31 Skyline) K&N high flow reusable type P/N 33-2031-1
Spark plugs 22401-58S16 (PFR6A11, CA1 Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm)
Spark plugs 22401-53J16 (PRF6B, SR20DET)
Crank angle sensor 23731-85M10 (CA18 all)
Crank angle sensor 23731-50F01 (SR20 all)
Coolant temp sensor 25080-89903 (S13 all)
Steering Rack Boot (LHS) 48203-10V25 (same as local 300ZX, mabey R32 also)
Oil pressure sender unit 25210 89920 (generic nissan??)
Oil pressure sender 25240-89920 (S13 all)
Cam shaft timing belt 13028-51E25
Cam belt idler bearing 30BD219DWAX
Cam belt tenioner bearing. 35BD219DWAX
Clutch Master Cylinder rebuild kit. PBR Aust. K8690 (contains pistons).
K7689X (rubber components only).
Clutch Slave Cylinder 3062069F03
S13 Main Handbook (English) Nissan Publication SM9E-OS13G0 $230 tax ex.
RS13 Service Manual, Main Issue (Japanese) Nissan A008009 $143 Tax Ex
SR20DET S13 Engine supplement Nissan A008011 $187 Tax Ex
SR20DET S13 Wiring supplement Nissan A108012
crank sprocket - 13021-D4200 - $29.26
woodruff key - 00926-51900 - $1.02
crankshaft plate (behind sprocket) - 13022-42L00 - $1.78
Turbo Manifold gaskets -> head:
14036-D4201 (x2)
14036-D4202 (x2)
KA24 and CA18 use the same radiators (Unlike the SR) with both ports on the USDM passenger side
www.raretrick.com seems to carry quite a few CA products, including SAMCO CA18DET upper and lower radiator hoses as well as turbo hoses.
for the water pump, if you use a pulsar pump you need a FWD pulley. get a CA18ET (S12 200sx) if you want to use the stock pulley.
Posted: Sun Mar 06, 2011 10:57 pm
by Grobblere
Installed the Vw Golf fluid temp sensor,the thread and length fitted perfectly and seems to be working 100%. They correspond very closely to the original Nissan sensor to my knowledge.
Nissan Charges +- R500 for the sensor, the golf one sells for about R145-190
I don't have the part number tho.
Posted: Sun Mar 13, 2011 9:04 am
by BigKriss
Go sit in the corner until you get the part number ! 8)
Posted: Fri Apr 08, 2011 3:15 pm
by BigKriss
Well, Nissan S.A. came through with parts for me once again.
Nissan factory spec WINDSCREEN, S14 !
Part number 7271270F15.
Price R6251.54 ex vat.
A spare is always good to have.
Re: Submit your part numbers
Posted: Thu Mar 15, 2012 3:36 pm
by Christiaan
200SX S13 1994 model front diskpads MP 662 D998 @ R220
200SX S13 1994 model rear diskpads MP 670 D3005 @ R340
CENTPART in Centurion.
Posted: Tue Jul 12, 2016 9:06 pm
by Hackeer
I stumbled upon a website that ships OEM parts for the 200SX at competative prices (versus local Nissan Dealers :-) ). The site is: https://www.amayama.com
I've used these guys for a few random items like window wash nozzles and a coil pack set. Point to note: if you search for the parts on the Japan catalogue, you need to select the '180SX RS13' (which is what they call the 1800 S13 model over there).
...and I got part-related question: Anyone know what would work as a replacement on the boot struts (the gas struts that keeps the boot lid up). The Bloemfontein Nissan guys cant help (part discontinued) and the local Autozone and Midas aren't very helpfull either :facepalm: .
