Got the radiator but unfortunately with my engine layout i cant fit both fans.
So I'm selling 1X Radiator + 2X electric fans .
The 1 one fan is a 2 speed and gets wired to come on with the aircon and then switches to full speed when the engine goes over operating temp.
rat wrote:Isnt that a SR one? CA has both pipes on the same side?
Not exactly , SR hoses sit's opposite to this one. The bottom pipe sit on the wrong site for the CA , didn't think of that cause it doesn't apply to my setup.
Wicked is running one in his sx and Pegasus was also using one before he started stripping and selling. You will have to modify the bottom pipe.
Make a turn and ill show you what needs to be done.
Charlvdw wrote:Wicked is running one in his sx and Pegasus was also using one before he started stripping and selling. You will have to modify the bottom pipe.
Cool, Will probably take it off you I just need to wait for my cash
Will let you know
