The bitch
- RB25SX
Re: The bitch
I used a EWP water pump for the same setup in a BMW track race car. Worked very well. Switched the water pump and fan on/off from the ecu optional fan output. On at 85 off at 80.
Use no thermostat or stock water pump if u use a temp. controller to switch on/off.
R32 GTR
Re: The bitch
how does an electric pump compare to stock pump? would the stock water pump not interfere with the electric pumps flow?
- RB25SX
Re: The bitch
U need to take the stock pump impeller out. Only use the pump housing. Get the Davies Craig EWP from Universal coolers in Pretoria. U can use their controller, or ecu temp output.SonOfAnarchy ZA wrote:how does an electric pump compare to stock pump? would the stock water pump not interfere with the electric pumps flow?
R32 GTR
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
Shot for the info man. Will give them a call soon as i start with the plumbing for the radRB25SX wrote:U need to take the stock pump impeller out. Only use the pump housing. Get the Davies Craig EWP from Universal coolers in Pretoria. U can use their controller, or ecu temp output.SonOfAnarchy ZA wrote:how does an electric pump compare to stock pump? would the stock water pump not interfere with the electric pumps flow?
Re: The bitch
Just watch out that those scared ass passengers dont kick out your wiring
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
Hahaha na man I will tie it up behind the dash soon as the ecu is wired up..
- Drillergy
- Real Name: Darryl
Re: The bitch
Awesome work man!!!!
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
Shot D!! So picking up my fuel cell from ATS today.. Its so shiny..
Time to start plumbing it all up now I guess
List to do
Fuel lines
Water lines
Clutch
Gearbox
Prop shaft
Ecu
Turbo
Intercooler pipes
New altinator
Starter motor
List to do
Fuel lines
Water lines
Clutch
Gearbox
Prop shaft
Ecu
Turbo
Intercooler pipes
New altinator
Starter motor
Re: The bitch
Awesome
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
Got a new gear box and arp flywheel bolts today. Jumbo box with bell housing. Been test fitting it in tomight
Man its one hell of a tight fit.
- 0.9 Bar Boost
- Real Name: ????
Re: The bitch
Picked up the flywheel tonight. Thanks BG!!!!!
That will go on the weekend.
- POWDER
- Real Name: Mike
Re: The bitch
Hey dude, starting to look well there man...
sent from my Sony Xperia X1
