poizen
Posts: 2994 Joined: Sat Apr 12, 2008 2:05 pm
Real Name: Mical Mackay
Post
by poizen » Thu Oct 14, 2010 11:42 am
hey guys
i need alil bit of help
im using my A.A.C as my idle control is this right
also does anyone have the ohms for the std water temp sensor so i can enter it into the system
and one last thing do i have to use the air temp sensor and if i do should it be befor the meth or after it
thanks for the help
poizen
Post
by poizen » Thu Oct 14, 2010 11:44 am
also does anyone have a start up map for me just to get to the tuner then ill put the 660cc injectors and tune
poizen
Post
by poizen » Thu Oct 14, 2010 3:45 pm
wow no help
Posts: 2991 Joined: Tue Aug 01, 2006 1:39 pm
Post
by Daniel » Thu Oct 14, 2010 4:19 pm
Well I think if someone knew the answer they would help.
And weren't you going to show us how easy it was to do
hope you come right bud
poizen
Post
by poizen » Thu Oct 14, 2010 5:25 pm
stil going to show you how easy it is just need the ohms for the coolent plug other than that everything is done pre loom done just need to push thru fire wall and pplug in then tune some one who has tator with ca18det must know just log on get settings pweety please
djtreble
Posts: 1502 Joined: Fri Jan 29, 2010 2:49 pm
Post
by djtreble » Thu Oct 14, 2010 7:02 pm
Here we go bud:
You got the S13 manual? It's in there under electrical.
poizen
Post
by poizen » Thu Oct 14, 2010 7:21 pm
thanks man i know these but i also need for
-20-
0-
20-
40-
60-
80-
100-
120-
but thanks for the help
djtreble
Post
by djtreble » Thu Oct 14, 2010 7:23 pm
Oh ok, well when it comes to electrics I know as much as the manual...sorry I cant be of more help
Posts: 5975 Joined: Thu Oct 12, 2006 12:56 pm
Post
by Gary57 » Fri Oct 15, 2010 8:38 am
It will be linear.
THEO 3K - ZN
Posts: 180 Joined: Sun Feb 03, 2008 6:56 pm
Post
by THEO 3K - ZN » Fri Oct 15, 2010 2:37 pm
piozn, you going to break it.....
MITSUBISHI TRITON 2.4 + VAT
200SX - 1.8T
OPEL CORSA UTE
MK1 GOLF - 2L 8V
GENERAL TURNING & MILLING
THREAD REPAIR & STUD REMOVAL
QUEENSBURGH TRADING
poizen
Post
by poizen » Fri Oct 15, 2010 2:56 pm
THEO 3K - ZN wrote: piozn, you going to break it.....
why am i going to break it
good news i got 2 opel sensors for water and air sweet going for dyno on monday
RudeBoy
Posts: 517 Joined: Mon Nov 26, 2007 4:11 pm
Post
by RudeBoy » Sat Oct 16, 2010 6:30 pm
wouldn't bother with the idle control, waste of time... blank it of and set idle on throtle body
you already figured to use the opel sensors (i have mentioned this here before - in powder thread) - but air temp correction i never bother with
dont have a map for ca18, i do for sr20... but you must remember to match your timing regardless of where you get a start up map from
(set trigger angle so timing value displayed on laptop, match actual timing light value)
poizen
Post
by poizen » Sat Oct 16, 2010 7:37 pm
thanks for the help rudeboy knew could count on you for help
THEO 3K - ZN
Post
by THEO 3K - ZN » Wed Oct 20, 2010 7:15 pm
It was a joke poizen.
You got the car back?
200SX - 1.8T
OPEL CORSA UTE
MK1 GOLF - 2L 8V
QUEENSBURGH TRADING
poizen
Post
by poizen » Wed Oct 20, 2010 8:41 pm
yip
227.5 BHP
and 272nm on the wheels it feels awesome
