Management Systems
- 0.6 Bar Boost
Management Systems
Okay, let's start this debate.
I want to fit a management system. the problem is that there is so many out there & everybody claims to be the best.
I thought of MrTurbo as there I can plug in my Laptop & load various FuelMaps.
I Also thought of Ram Mapping where they keep your existing fuel maps & just add more.
I thought..of....& the list goes on. What are your guys thoughts on this. Someone said Unichip is da best...
- Daniel
- Real Name: Daniël
ok, im no expert (wel obviously ) but can you even do Ram mapping on our ECU's ?? dont you need ODB2 for that?
Im sure a Unichip is alright. but has limited functionality compared to even the local managemant solutions.
Dicktator is the only 1 iv'e ever seen advertise for the SX, but im sure most if not all can work. So far id have no problems going with Gotek, Mr Turbo, Dicktator or any1 of the main local brands. Price is obviously a factor and no local systems seem to cator for electronic boost control where the international (and outragiously expensive) ones do.
As a side note, I have a EEPROM programmer and some software to make the changes. Can more than likely still get the chip in the ECU and I have a very BASIC understanding of the settings.
I.E: theoretically i can program my own maps and whatever and plug it directly into the ECU inplace of the old 1
lemme post up what i know so far, maby some of you have some ideas. Obviously im too scared to make changes plug it in and see what happens. Perhaps once i get down to doing some decent research.
Chip Type : CA18DET ECU uses 27128A chip
(27) EEPROM Type
128 EEPROM Size 16kb x 8
A ????
Need the widths.
Sections
Address = Offset in binary file
Siz = Size or #bytes of data
Fac = Factor x = times, -reduce
Info = Information
Address Siz Fac Info
0x3690 16 x1 TP Limit (AF Limit)
Word Data
Boost Cut
0x3700 256 x1 Low Octane Fuel Map
0x3970 8 x1 Acceleration increase volume
0x392C 1 x2 Speed Limit (kph?)
0x3980 1 x50 Rev Limiter 1 7200 (90)
0x3981 1 x50 Rev Limiter 2 7000 (8C)
0x3982 1 x50 Rev Limiter 3 7200
0x3983 1 x50 Rev Limiter 4 7000
Pairs must be the same i think ( 0x3980 and 0x3982 ) and ( 0x3981 and 0x3983 )
0x3990 16 x1 Add Map 1 (Variable air close)
0x39A0 16 x1 Add Map 2 (Variable air open)
0x3A00 256 -22 Low Octane ignition map
e.g. 0x24 top left of table is 36 dec less 22 = 14 Degrees at idle to 400 rpm ?????
0x3BC0 16 x1 Fuel TP scale
0x3BD0 16 x50 Fuel RPM scale
0x3BE0 16 x1 Iginition time TP scale
0x3BF0 16 x50 Iginition time RPM scale
0x3C00 256 -22 High Octane ignition map
0x3D00 256 x1 High Octane Fuel Map
0x3E18 104 x1 VQ Map
Word data?
0x3F40 16 x1 TTP MAX/MIN
Total Theoretical Pulse Width Min/Max
48 48 48 48 50 50 58 58 b3 b3 b3 b3 b3 9a 9a 9a <--- thats the data
0x3F80 2 x1 Required K Number
Injector Value. Multiplaction factor for setting the pulse width of the injectors.
0x3F8F 1 x1 Void blast off time
Injector latency, time For an injector To open And close.
(27) EEPROM Type
A ????
Need the widths.
Sections
Info = Information
Word Data
Boost Cut
Word data?
- 0.6 Bar Boost
Damn! That's amazing. This sounds like what ChipLogic does. they access the existing chip & make changes. Maybe there are settings on the internet one can find that allows for better fueling & higher boost etc,etc.
Will the ecu allow you to make these changes? I would think Nissan Lock the ECU some how....Just a guess
Here is my opinion, I have a unichip, you can map it just as good as an management system, the problem is you are also limited, it will cover a bigger scope of mapping, that will give you the same as an management system, but as I said it's olso limited where an management system covers an even bigger scope of mapping which you can alter yourself with a laptop for racing eg.
Pros unichip:
cost less to fit R1400+-
for the normal guy on street that needs perfotmance.
Generally lighter on fuel...(not mine)
Caters for all fuel/air needs.
faster to fit.
Cons of unichip:
limited in terms of racing
for the normal guy other than Daniel it is hard to remap.
Pros of Management:
Wider scope and can do it yourself
For the racer if need be
kicks out all extra coils, meters and stuff that generally gives you an headace.
Cons of management:
Costs more +- R4000 to buy and install
generally heavy on fuel
can scrue up if the right people don't do it
takes longer to install
Pros unichip:
faster to fit.
Cons of unichip:
Pros of Management:
Cons of management:
- Toby
- Club Founder
- Real Name: Toby Kurien
I have a ROM editor for the standard ECU if you want - you can make your own map! Just unsolder the original EEPROM, solder in a socket, then you have the option of using an EEPROM emulator via a laptop (which allows you to remap on the fly), or else just program the EEPROM and stick it in. Anyone interested in the details?
- Toby
- Club Founder
Yea I played around with it and it looks good, though I never actually downloaded the ROM into my ECU. It's very funny though, 'cos the menus are all translated into English from Japanese, so to load an address file, you click the menu that says: "Are crowded as reading address file" heheheh
But the 3d view is great - kinda works like the laptop in the first fast & furious If anyone wants to mess around with it, I have enough electronics knowledge to help you screw up your ECU And I can program EEPROMS. I could even try to build an EPROM emulator for a laptop.
Here's what it looks like:
Some info on how to use it:
http://www.sr20forum.com/archive/index. ... 65087.html
And great info here:
http://www.sr20tuning.com/theoryandpartsrequired.html
