Upgrades on 200sxrb25
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
what turbo are you running there?
what sort of power goals are you after?
Current. CA18DET S13
200sxrb25
Post by 200sxrb25 »
[img][img]http://i852.photobucket.com/albums/ab81 ... nrb254.jpg[/img]
Made up brackets for strut brace.[/img]
200sx rb25
lotus 7
200sxrb25
Post by 200sxrb25 »
[img][img]http://i852.photobucket.com/albums/ab81 ... nrb252.jpg[/img]
Made up a adaptor for throttle std body.[/img]
200sx rb25
lotus 7
200sxrb25
Post by 200sxrb25 »
nirvash wrote:what turbo are you running there?
The turbo is a T58 and i will be happy with 280kw at 1.2 bar boost.
200sx rb25
lotus 7
200sxrb25
upgrades
Post by 200sxrb25 »
I started the header's pipes, it took me about 4 hours to make.
200sx rb25
lotus 7
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
are you still running the standard head gasket? (hence the 1.2 if thats your boost limit)
200sxrb25
Post by 200sxrb25 »
are you still running the standard head gasket? (hence the 1.2 if that's your boost limit)
Yes,will be the standard head gasket. I going to fit water/meth, so i can boost higher and make more power. Will see how high can i take it on standard head gasket.
Going to fit 550cc injectors
Walbro fuel pump and avgas on race day's.I think i can make more power.
200sx rb25
lotus 7
RB25SX
Post by RB25SX »
Looking good, u should have used a one piece flange against the head, easier to skim after all the welding.
R32 GTR
200sxrb25
Post by 200sxrb25 »
RB25SX wrote:Looking good, u should have used a one piece flange against the head, easier to skim after all the welding.
Thanx, using the single flanges for expansion, I've heard of headers keep on cracking with one single flanges.
200sx rb25
lotus 7
200sxrb25
upgrades
Post by 200sxrb25 »
Done the pipe work today.
200sx rb25
lotus 7
Nice :!: :D
200sxrb25
Post by 200sxrb25 »
I'm looking for front tension rods. Can some one help me with a set.
200sx rb25
lotus 7
200sxrb25
Post by 200sxrb25 »
Got a walbro pump today.
200sx rb25
lotus 7
200sxrb25
Upgrades
Post by 200sxrb25 »
Is a 600x300x76 inter-cooler big enough for the rb25, have to get a new inter-cooler.Who in CT sell inter-coolers at good price?
200sx rb25
lotus 7
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
that size should be good, the exact size i'm running on mine
dont feel any lag even with this size, with my standard turbo
about where to find one i'm not 2 sure which place is your best bet
what fuel pump were you using before your walbro by the way?
