I'm pretty sure that is a narrow band lambda? not great for measuring AFR's.
If I recall correctly from the manual base fuel pressure should be set to 36psi, best to check the manual though as its quite a procedure you need to follow.
Overfueling Issues Ca18det
- Daniel
- Real Name: Daniël
Re: Overfueling Issues Ca18det
ok will do bud thanks
