Overfueling Issues Ca18det
So ive been reading other topics and searching too, which has been quite informative but i need some specific advice.
i know a little a bit bout my car and engine but its not enough to trouble shoot myself.
Engine runs really well, i have a 63mm exhaust with no engine mods & it makes 131kw. i believe if it aint broke dont fix it but ballwashing is my concern!
I have checked and i get about 375 - 400 km off a tank(45l). Ive checked my air fuel ratio and its bad in 10 11 12s full throttle 3rd & 4th cant remember exactly but cruising at 120km/h is also bad low 13's i think. Exhaust and Bumper is always black from smoke/unburnt fuel!
My question is Does it need to be tuned, or is there another problem ie faulty fuel pump or afm or leaking injectors.
i dont have a management system but im fitting one soon probly Diktator.
Would love Nistune but ders nobody to tune it, or help me tune it in CT.
Lemme know wat u guys think.
Thanks
Deon
Thanks
Deon
hi Deon
i had a similar issue
i think also check your thermostat &
all bost pipes .Then if no difference the question of are your long term plans to leave your ride standard (reliable
or go mods start
if standard go Visit Lynx motorsport (Bosch agents )
please wear an adult nappy when visiting their premises
or go mods start
if you can drive it drift it
Thanks Guys
i'm gonna service it, then i'll check the thermostat,fpr and boost pipes and clean afm. What do lynx motorsport do? Can they check error codes.
"Not returning to the fuel tank"... I was also thinking FPR cos if i Gun it or give a the High rev then the revs drop all the way down and car goes off
For my dirty bumpers or dirty paint i use Meguiars ultimate compound, it removes light Scratches, swirl marks and any dirt...really works well
checking for error codes on the ca18det is really easy to do yourself, there is a step by step guide and explanation of codes in the FSM, or simply do a google search..
something like this..
http://forums.nicoclub.com/zerothread?id=270584
this should really be the first thing you do
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
- THEO 3K - ZN
@ 300sx, I did all that mines still overfuelling.
Its idling at 1400rpm all the time, power is there and im only boosting 0.5bar with std management
Fit a fuel pressure gauge? would a struggling fuel pump be the cause?
MITSUBISHI TRITON 2.4 + VAT
200SX - 1.8T
OPEL CORSA UTE
MK1 GOLF - 2L 8V
GENERAL TURNING & MILLING
THREAD REPAIR & STUD REMOVAL
QUEENSBURGH TRADING
200SX - 1.8T
OPEL CORSA UTE
MK1 GOLF - 2L 8V
QUEENSBURGH TRADING
Re: Overfueling Issues Ca18det
what should the normal afr be??
14.5 - 14 .7
..... when i boost in3rd its on 19.5/20
That's beyond dangerously lean. Bye, bye, engine.
(Of course that assumes you have an accurate AFR reading)
Eish.....
Any 1 have forge pistons ... gonna rebuild the motor and put a dicktator ... ;-(
- Daniel
- Real Name: Daniël
How are you measuring afr's?
See if someone is willing to loan you a working AFM to test with.
What is your fuel pressure? Are you using the standard fuel pressure regulator, have you tested it?
Sent from my GT-N8000 using Tapatalk HD
Hey bud i got a vr6 lambda with a prosport af guage the fuel pressure i will have tested this weekend and yes its a std fuel pressure reg .. I have a aftermarket one that im going to install 2 morrow it has a guage on it ... what fuel pressure can i run? on standard injectors???
