High Boosts SX
- Highboost
Please guys do not misunderstand me
My car is not the only one in the shop,(as I have said before) I am a
very "eager" person, and Yes I do visit or check up much to
often.
So please what ever work was done so far, are first class, of the best you
can find !!!! For me being a bit selfish I would have loved for the job to
have been further along, But as Rudeboy have said I don't want him to
tell me to F off or to rush the job...
I am just very very excited to get this done, and I suppose I have
overdone this totally. I appologise If I created the wrong impression.
I'm just very eager to drive the bugger....
often.
- RudeBoy
- 0.5 Bar Boost
its all good - no worries - RB's are very nice to drive, so your eagerness is understandible, but its worth the wait
was mearly stating the impression reading this was giving me
good luck with the rest of the build, see you at drift practice with it soon
(p.s) only after we check the static timing
and one 3way ignition module can def run this on wasted spark
- The Doctor
- Highboost
For sure !! Timing is a killer..
O yes and the bonnet closes properly.
Update: propshaft has been taken in, will get that back at 16.00,
I do not have any electrical plugs for injectors, coils, alternator or
sensors...... so its scrap yard hopping for me again.
Any ideas which "normally available" cars uses the same plugs?
- The Doctor
- Highboost
Got the Propshaft back, and it fits like a clove.....
Also re-rooted some of the wiring, to the other side. With the Toyota motor
vs. the nissan motor everything is turned arround.
Tonight: Will be swopping the clutch slave cylinders and moving the piping
to the drivers side. Also will be making up a wiring loom for the coil packs.
- The Doctor
