SR20DET TB Modification to replace CA18DET TB
ChemCool
Post by ChemCool »
Yes, the diffs is about 5mm's.
Ok, Gary, I understand the boost situation. All I can say is that I basically have T28 now, or is it the t25g??/? Some more boost available, and no fmic, less lag, straight into the tb. But it was not a shlep to do the mod. It is done. it is there and that is it. Need to dyno.
Chem 8)
COOLER, FASTER, LIGHTER
Thats it Chem, I would do it for the experiment if nothing else.
Would be nice if someone could dyno a car then do this mod,redyno to check if their are any gains.
I will do this mod if I can come up with a TB for a good price.
mario_200sx
Post by mario_200sx »
Well, I will do this. Just need the throttle body!
Doctor G
0.7 Bar Boost
Post by Doctor G »
Okay so after some research it seems the CA TPS has a voltage between approximately 0.5V and 4.0V+ between idle and WOT.
This compares to a SR20DE TPS just fine.
However, when I went to check the actual TPS voltage on the CA I could not get any reading. I usually measure the TPS voltage on the SR by sticking the multimeter prongs into the back of the TPS plug wires.
On the CA TPS there are 3 prongs on the TPS, but only two female receptors on the TPS plug. Is that correct? I couldn't get a TPS reading measuring no matter which way around I used them multimeter.
Does anyone know how else to test the TPS voltage aside from measuring it at the ECU pins?
ya ya you clowns. :lol: :lol: :lol:
the black connector on the TPS is just the idle switch!!! you can measure this on the ohm (resistance) setting on a multimeter!
the grey 6 pin connector zip-tied to the water pipe below the TPS, and connected to the TPS via a small wiring harness (covered in black protective sheathing), is the actual throttle position sensor.
that should give you readings!
FSM shows all this stuff guys! :wink: :wink: :wink:
