Howsit Guys
are there any options of other diff ratios on a S13 chassis? for example some other internals of other Nissan's that might fit to give you different ratio options.
S13 Diff ratios
Re: S13 Diff ratios
can mod a s14 diff in fairly easy swap
Re: S13 Diff ratios
what ratio does the s14 have compaired to the s13?
Re: S13 Diff ratios
If i remeber correctly a s14 has a 4.1 but i could be wrong all i do know is it will give a longer ratios google is your friend lol. there was 2 s14 diffs for sale on the forum
Re: S13 Diff ratios
what i can find online is that the s13 has a 4.1 LS, i need something close to under 3...
Re: S13 Diff ratios
The Z31 internal also fit, believe that will get you close to what you want.
