Ca18det's with t3/t4?
hey guys i just wanted to find out how many ca's are out there running t3/t4 turbos on stock internals what power are they making with bolt on mods and a ecu (dicktator ect..)
reason for this is im busy fixing up my ca it needs new rings compression is low so was wondering idf its worth me putting on my garret t3/t4 hybrid stage 3 ? i dont have alot of money to spend so im avoiding forge parts. im keeping the ca (no motor swaps please ..) my t25 is buggared the exhaust housing is cracked badly and there is shaft play.
Re: Ca18det's with t3/t4?
so.. what exactly is a t3/t4?
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
its a turbo......
lol.. really.. what turbo..
what im trying to say is : how long is a piece of string?
a t3/t4 is a hybrid consisting of a t3 compressor mated to a t4 turbine .. considering the wide range of t4 turbines, and even more wide range of t3 compressor wheels, you can have a t3/t4 turbo suited for a 5 liter v8.. and certainly also a t3/t4 suited to a ca18det..
hence the question.. without knowing what size t3/t4 you want to fit to your ca18 the question is pointless
300zx fairlady 1991
- 0.9 Bar Boost
- Real Name: ????
hahaha look at the ar housings to see the size of the turbo you want.. basic ca set up looking 160 to 180 depending on the motors life and how long you want the car to be running
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
If you are looking for a small-ish T3/4 turbo then a ar50 housing with a 52mm compressor and a stage 1 exhaust wheel with either ar.48 or .63 housing should work fine if you want the car to boost early.....
T3 AR.63 Turbine Housing T3 stage 3 Turbine Wheel T04E AR.50 Compressor Housing Compressor Wheel(76mm) garret turbo . this is what i have
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
lol well if he has enought time the turbo could start boosting by Christmas
what would the correct setup be for a t3t4 to spool up at around 4000rmp
A 0.48 housing at least, anything bigger and the lag will be heavy.
- Grobblere
- 0.6 Bar Boost
- Real Name: Eugene
Careful for the small housings, if the rear housing is too small it also leads to massive heat at the exh side.
Regards
Regards
i got 1 bar boost at 5000rpm but my rings are badly worn so i couldnt really test it much . busy rebuilding the motor now will let you know how it does and yes the turbo has a bit of lag hahaha
I have a 48 housing with a stage 3 exhaust wheel and have full boost around 4200-4500rpm. Doubt if yours will change after rebuild.
oki bud maybe ill look at getting a smaller housing .
