200SX S13 rear brake discs
mario_200sx
Post by mario_200sx »
Hi guys,
A company Im bringing some parts in from overseas end of the month is stocking some S13 rear discs.
Specs are following:
Technical details: Herth+Buss brand
•Fitting Position: Rear Axle
•from construction year: 09.1988
•Diameter [mm]: 266
•Surface: Coated
•Brake Disc Type: Solid
•Brake Disc Thickness [mm]: 9
•Bolt Hole Circle Ø [mm]: 114,3
•Number of Holes: 4
•No. of holes 1: 2
•No. of holes 2: 1
•Inner Diameter [mm]: 172,3
•Minimum Thickness [mm]: 8
•Height [mm]: 62,6
•Hub Diameter [mm]: 68
Are these correct for our cars? Anybody that wants to place a order for them?
They come to a R2400 for a set (2 discs). Landed, VAT & Tax included.
Rolling Thunder..........
