Hi guys had the misfortune of driving through an oil patch this evening on my way home, surprisingly 5 tow trucks appeared out of nowhere under 60seconds not that i can prove anything but i would say the oil didnt come from the sky, anyways, i spun out at low speed and hit the curb with my front right wheel, control arm bent and castor rod tore, need a replacement asap, doesnt matter if the castor rod bush is torn, will have to poly mount it to match the passenger side anyways, please guys any help would be great.
Thanks
URGENT S13 front right control arm and castor rod
Re: URGENT S13 front right control arm and castor rod
might be able to help you out pm me your number
Bump!
Still in need of a front right control arm please.
