S13 Ichiba hub Studs
I need 4. The base is wider then normal studs.
Ero_sennin
Re: S13 Ichiba hub Studs
Post by Ero_sennin »
arnt they suppose to be the same? How is the quality overall though?
SONY Xplod inside
SR20DET Powered Red RS13
Quality good. Used for 2500kms.
The rears are normal Nissan 12.5 /13mm
I used spacers with extended studs and can't find all my stock ones.
Same a S14 fronts. 14.25mm will go to Nissan and find out.
I need front hubs.
