Nissan 200SX s13 sr20det ***SOLD***
cheetor
Post by cheetor »
http://johannesburg.gumtree.co.za/c-Car ... Z427463312
Nissan 200 sx s13 1991
Sr20det red top engine
Newly rebuilt engine
new sleeves
new pistons Sr20det and dished 1mm
new acl race big ends and mains
new oil pump from japan
head flowed on flow bench and port matching
Pulsar GTiR quad throttle bodies 45mm each x4
toyota 7mgte fuel injectors 420cc
custom fuel rail top feed
custom intake manifold
engine is balanced
head is completely redone
cometic gasket full set
intake venier pulley
Rocker arm stoppers
new 76mm exhaust system
gearbox redone at mayfair gearbox centre SR20 rwd 5speed
recon propshaft
2x fuel pumps , navara v6 pump in tank and inline 6.0bar fuel pump
adjustable fuel pressure regulator
oil catch tank
Master power t3t4 turbo still very good condition
external wastegate and screamer pipe
front mount intercooler and dumpvalve
new s/steel boostpipes and silicon couplings
lightweight aliminuim pulley set
new water pump
recon altenator
recon powersteering pump
New V-belts
dual electric fans
bigger radiator and reconed
button clutch
imported smoked indicator lenses in front,smoked indicator lenses rear
carbon wraped bonnet and lifted for cooling purposes
interior very good condition
New cluster lens, needle's green,interior bright led's,footwell led's
new boost gauges,water temp gauge, coolent temp gauge built in centre panel
custom made gearpouch
8000k hid headlights fitted
tyres in very good condition
smash and grab tinted windows all round
shaved bootlid, body is good condition few small scratches
Blacked out roof with sunroof
17" lenso mags
Engine has done 12000km
Koni shortend shocks and Koni 40mm lowered coil springs
Small dings Removed
Daily Driven
R70 000neg.
Please no swops
Contact 072 694 0 four two five
1991 Nissan 200sx S13 252rwhp & 2..nm
ex 1972 Ford Fairmont GT 5.8l V8 224kw
Re: Nissan 200SX s13 sr20det
Seen this car up close one of the best sx i've ever seen know the mechanic he's got very good attention to detail car is a great buy would take it in a heat beat if i had the cash. Good luck with the sale
future sx owner
Post by future sx owner »
cheetor
Post by cheetor »
car is sold, and yeah saw that... stupid people trying to cause problems for others!!!
