Devil Pig Drift / Track car S14 Ls1v8
Booster
Post by Booster »
Hey everyone. Im new to the forum. Name is Mybo.
Been following the drifting scene since early days. about 5 years now. Mostly just watching from the side lines. Taking the time to do research, on what i should do.
Now its time that i take part. The itch is just too much
Thought id share my project with the boys.
I originally paid a local "tuner car builder" to build me a drift car.
Long story short.
After 2 years a decided to build it myself. Fetched all my stuff, lost a whole bunch of money :(
and here we go
Booster
Re: Devil Pig Drift / Track car S14 Ls1v8
Post by Booster »
My rota grid gtr 17's
the engine im running in the car will be a Ls1 V8 5.7, borg warner T5 box, tilton twin plate clutch, 3 stage dry sump system. other few bits and pieces ill show you later.
dry sump and tank
cobra seats
drift works suspension goodies
sub frame bushes
lsd
Booster
Post by Booster »
stripping car.
Preping the seems for stitch welding
welding
fitting motor to figure out clearances for engine mounts and sump etc etc
nomnomnom
Booster
Post by Booster »
some rust i found. cut out and welded new section in
some painting, my little babe drift princess to be, helpign me out
new section i welded in
sub frame sandblasted
primed
painted
bushes installed
done
Enzio
Post by Enzio »
1 - you shouldn't lift heavy stuff with your back like that, use your legs.
2 - nice project, good luck! This has lots of potential!
Booster
Post by Booster »
:) yeah ...lucky its aluminium block
Booster
Post by Booster »
fabricating my new sump,
end result
box mount
turned up a spacer on the laith, Im running the dry sump pump off of a pulley im mounting infront of the crank dampner.
LS powered 200! Gosh I hate you so much!
Coming along nicely :wink: definitely going to be watching this thread.
Booster
Post by Booster »
Some bits off to powder coating
back
installed
my fly wheel
new boss riveted for splines on T5 box
old splines
Clutch done
Booster
Post by Booster »
Stone chipped the bottom and wheel arches, Also fitted the suspension goodies
also made up some diff aluminium bushes and fitted them
couldnt help get some wheels on to check out the stance
My boy "boost".....he cant wait to skid this thing!!!
Drift godess cruizing with dad....chowing ice cream
tim the get the engine in
last minute panel beating taking place
and she was lank proud of her new dents
FINALLY......her resting place
new sump clearance
Front suspension
Im mounting the dry sump tank in front at the passenger side
busy measuring up for the pump bracket
Booster
Post by Booster »
Big problem i had was finding 5 stud hubs....So after a long while i designed my own hubs.
Im using a bearing from a nissan xtrail
Booster
Post by Booster »
Booster
Post by Booster »
some chucnks of steel en36b for the hubs
gave them to my workshop,
few days later i got these beauties
front, still need to tap and drill for threads
back
note the bearing is not pressed in hear, its simply how they will be assembled
front with studds
how the bearing fits, neeed to be pressed
bearing locating
quick mock up
Booster
Post by Booster »
small clearance issue with back tyres
had to cut out inner skin and roll the arches
started fabricating my strut braces
made these tubes
installed with nut inside
tacked in place
still need to finish them off
