My 200sx and the issues (Pics ADSL)
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
Hi Guys, I have created a new threat as to work on all the individual technical issues around my car and also added some pics so that i could update as we get stuff fixed as we go along. And should be a good guide for anyone also buying or wanting to fix up a 200sx.
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
I have installed the Hyundai Elantra brake pads today they work perfectly product code is Fdb600-cer (ferrodo) i got them @ R365. ( will post pics later)
By this weekend ill pull out the interior and wash everything. Service the engine with all the necessary bits and also try to sort out the late boosting. I will keep you guys up to date with the fault finding should help allot of people with similar issues
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Real Name: B.G. Smit
Post by P3g4sus »
Moved to Articles for you.
Its more a build tread! :wink:
Good luck with the Build! :D
aep886
Real Name: Davey
Post by aep886 »
i have a S14 boot spoiler for R200 if you interested^^
current vehicles...
1979 Corolla SR5
1996 S14 200sx
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
Hi guys
So today we got all the items mostly sorted, the cam timing was out on the intake and exhaust,, but the fuel pump loses pressure when the car gets into boost :(
Any idea where i can get u a good pump?
Thanks! do you have pics of the wing? if it looks good ill really appreciate it
Best regards
Eugene
walbro pump www.rezlo.com
FUEL PERFORMANCE
Post by FUEL PERFORMANCE »
Grobblere wrote:Any idea where i can get u a good pump?
I have pumps arriving this coming week.
PM ME!
FUEL PERFORMANCE SA-UK-EU
HIGH FLOW SA-UK-EU
godzilla
chips
Post by godzilla »
since your car is white u can use a white grout pen(by plascon) to touch up the chips untill u can have it sprayed.most big hardware stores carry them .
sideways forever....
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
Hi Guys
Just to get you updated. So i replaced the Fuel pump with a Bosch unit and set the cam timing.
The cam timing is definitely right, we checked the marks but the car seems to have even less power and shakes a bit...We did hook up a pressure gauge to the fuel line and i dont really think its the fuel pressure regulator.
What do you guys recon it migth be? how would i check if its the N/a cams in my car
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
I got allot more work done, but here's a little update :D
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
What do you guys think of the car with this wing? Its the new camry wing seems to fit very well. Just need to get a way to plug those holes permanently
(To be edited)
Heres some pics of my prev ride :D
15.1@ Tarlton (pump gas, street setup, wheel alignment was out due to a replaced control arm
N/A 154whp&181nm torque on the wheels with pump gas ,street setup and uncorrected :D
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
Just wan to mention the wing is not fitted! Its only placed on top of the bood.
Will spray it 2 morrow :D
Grobblere
0.6 Bar Boost
Real Name: Eugene
Re: My 200sx and the issues (Pics ADSL)
Post by Grobblere »
So guys, atlast an update on my cab.
Had TSW 17" mags fixed, but they where not properly sealing and cracked after a few kilo's ,instead i replaced them with Enkei Ev5's with brand new tires.
Took the whole motor out, reconned the head and fixed a couple of other items like a bent exhaust manifold ans, replaced lifters, cam belt and some pulley bearings.
Also installed a SR20DET turbo on it, but in very low on boost.
Future plans.
320D inline fuel pump, Custom exh mani and T3/4 turbo with +-70mm exhaust....just to get things started :domo:
Looks good!
Just get it lower
Grobblere
0.6 Bar Boost
Real Name: Eugene
Post by Grobblere »
Thanks Daniel
I would like to have a look at some coil overs instead of springs, but i agree that car would lokk allot better if lowered :D
Some say you can walk underneat it, others claim its a 4x4,....but we call it TREKKER! lol (lame i know)
