and how much longer till it runs? and can drive on the road?
POWDER
Real Name: Mike
Post by POWDER »
SonOfAnarchy ZA wrote:and how much longer till it runs? and can drive on the road?
Ye man, fully registered for the road and licence up to date 100%...
Probably about 2 more weeks then should be driving...
sent from my Sony Xperia X1
POWDER
Real Name: Mike
Post by POWDER »
Ok so I got the spacers on yesterday... TJO, what a diffirence....
The spacers, 4 X 114 X 30mm, awesome quality....
BEFORE:
AFTER:
I'm very happy with the look now...
Happy I got the wheels of too... If I didn't I would never have noticed this....
Let's just say drifting with 2 Deg Camber is not healthy for tires
steel spacers?
POWDER
Real Name: Mike
Post by POWDER »
Stainless Steel... No rusting...
POWDER
Real Name: Mike
Post by POWDER »
Just a few more stance pics...
POWDER
Real Name: Mike
Post by POWDER »
I gave my custom cluster to a very good friend of mine, in return he gave me his stock cluster and surround... After a good clean it looks like brand spanking new... So shimmery....
I think I will be more content with the stock cluster, I'll just spice it up a bit with a two stage LED lighting system... I'm thinking to start the cluster lighting of with white or blue ultra brights, then will make it turn red when my SX hits the limiter or something... That way I can keep the stock look and still be a bit diffident....
Real Name: ????
Post by Adrian »
Congrats man your 1st set killed kinda.
awesome wheel spacing. Looking a lot better
POWDER
Real Name: Mike
Post by POWDER »
Adrian wrote:Congrats man your 1st set killed kinda.
Shot brother... Ye I loved the first cluster I made.. It was epic but I just want a slight twist on the original now, as nice as the first one was, I don't think I would ever have been happy with it...
I'm also living the stance now, makes the entire car look wider and not so long...
POWDER
Real Name: Mike
Post by POWDER »
Pulled the cluster apart today and started scrapping the colour of the stock warning light mask...
Took a bit of time but now they all shine through white and are ready for the Red LED's... I have decided to make the pictures shine blue though to match the clock which has a blue filter stuck over the back anyway...
The control arms were a little faded so decided they need a little tlc...
Put everything back and all looking brand new...
The clusters wiring at the back is pretty simple, 2 separate circuits controlling normal illumination and the other controlling the warning lights, all the warning lights having a common positive on the bottom... This is important to know so that you know which way to wire up the LED's.
The first ultra bright LED wired up with an 820ohm resistor to aid with some extra brightness... Just hope it will be bright enough as I am using 3mm LED's for the warning lights. I will be using 5mm for illumination though.
Tomorrow I should hopefully finish up the rest of the warning led's
Awesome! Still want to do this mod too! And I've got a spare cluster, so should be good.... mmm... noe just to get the 180km one from nate...
have you put something in front of the led to disperse the light? if you put it in like that its going to have bright spots. i would suggest going and buying the smd bulb replacement i found that works the best
POWDER
Real Name: Mike
Post by POWDER »
Yup I know of that issue, but I'm aiming for a certain look, ye shall see
ok kwl
POWDER
Real Name: Mike
Post by POWDER »
Low and behold, Some more progress happened this weekend...
So I took some items to VDM again to have customised so that they will work in my new setup... Shane's epic skills at hand again...
Wastegate adaptor done, as the mountings are well in the way
Wastegate done, running nicely parallel and under the exhaust...
Radiator water outlet on the bottom tiled upwards so that radiator fits with out blocking the outlet...
With the top of the rad, instead of building new tanks, a bleeder nope was done at the highest point to eradicate airlock...
We also decided to put mounting onto the Radiator and IC to make mounting alot easier...
The exhaust made last time also had to be modified to fit the new manifold
As soon as I take pics of the complete boost pipes and installed setup I will update further...
