SOLVED: Tractor BigZ
Mister_Swartz
Real Name: John
Post by Mister_Swartz »
Hey guys.
So, BigZ is running.
Over the weekend I had to replace the exhaust manifold gaskets. They were all blowing and burning through. So as you can imagine it sounded like a tractor lol. After replacing the gaskets, I thought it would change. It didn't.
The bakkie idles and accelerates almost like it's got an intermittent miss. And under hard acceleration, she backfires a helse lot.
P.S. - changed the spark plugs as well.
I wanna learn to drift!
Current rides:
Nissan Hardbody -》CA18DET - Dicktator Wasted Spark, WR280, FMIC, AFPR, 57mm exhaust
Nissan NP200 -》stock
Ex rides:
Nissan Sentra 160Si -》CAI, 50mm f/flow + 2 57mm boxes
Re: Tractor BigZ
Check for leaks maybe between turbo and mani check for vac and boost leaks
Mister_Swartz
Real Name: John
Re: Tractor BigZ
Checked all of those.
No leaks...
Could it be the tune?
Maybe timing?
Current rides:
Ex rides:
Re: Tractor BigZ
No wont be tune maybe clois are on the way out make sure u have good grounding
Mister_Swartz
Real Name: John
Re: Tractor BigZ
Found the problem.
2 injector plugs weren't on properly.
So she was missing on them.
Current rides:
Ex rides:
